powerpc-rtems-4.7-gcc-4.0 patch commited
Sergei Organov osv at topconrd.ru
Fri Feb 18 11:47:41 UTC 2005
Ralf Corsepius <ralf.corsepius at rtems.org> writes:
> E.g. the m8260 would be superflous, if it could be removed from cpukit.
> The code it uses is _identical_ to the 603e, except of 1 define in
> cpukit.
Well, which one of the following 8 do you mean? Or am I missing
something?
cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h:180:  || defined(mpc860) || defined(mpc821) || defined(mpc8260))
cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h:192:  || defined(mpc860) || defined(mpc821) || defined(mpc8260))
cpukit/score/cpu/powerpc/rtems/old-exceptions/cpu.h:204:  || defined(mpc860) || defined(mpc821) || defined(mpc8260))
cpukit/score/cpu/powerpc/rtems/old-exceptions/cpu.h:216:  || defined(mpc860) || defined(mpc821) || defined(mpc8260))
cpukit/score/cpu/powerpc/rtems/score/powerpc.h:211:#elif defined(mpc8260)
cpukit/score/cpu/powerpc/rtems/score/powerpc.h:461:#elif defined(mpc8260)
cpukit/score/cpu/powerpc/rtems/score/cpu.h:407:  || defined(mpc860) || defined(mpc821) || defined(mpc8260))
cpukit/score/cpu/powerpc/rtems/score/cpu.h:436:  || defined(mpc860) || defined(mpc821) || defined(mpc8260))
Sergei.
