General Question: Saving Configurations
Steve Holle
sholle at link-comm.com
Fri Feb 18 15:30:35 UTC 2005
Our system starts up in MicroMonitor which we then use a script to start
RTEMS. We use many of the Micromonitor networking and filesystem calls
from our RTEMS code and have found it makes an excellent debug monitor
also. Mr Sutter is very responsive to support and feature requests.
Highly recommended.
At 05:36 AM 2/18/2005, Ed Sutter wrote:
>Paul,
>The file system in MicroMonitor's TFS would probably work
>out well for this. Generally speaking TFS is most easily
>used by the application if MicroMonitor is used as the
>boot monitor (if you're interested in this let me know).
>Alternatively, I suppose TFS could be yanked out of MicroMonitor
>and used as an alternative means of flash file storage in
>RTEMS.
>Ed
>>Hi All,
>>I am about to create an application in which I will be
>>saving configuration details.
>>The board I am using has flash memory on it, and currently
>>I am thinking of just saving the configuration into
>>a section of the flash memory.
>>I was wondering whether it is worth using some sort of
>>simple file system,or if there is a more generic
>>approach other people have taken.
>>Thanks in advance
>>Paul
Steve Holle
Link Communications, Inc.
1035 Cerise Rd.
Billings, MT 59101
