Something screwed up in PROJECT_ROOT or PROJECT_TOPdir
Peter Dufault
dufault at hda.com
Sun Feb 20 03:16:36 UTC 2005
On Feb 19, 2005, at 11:31 AM, Ralf Corsepius wrote:
> Wasn't it you who had problems with a broken m4?
> Your symptoms also can be symptoms of a broken m4 or sed.
I tried again.
I installed gnu sed 4.1.4, gnu m4 1.4.2, gnu make 3.80, removed the
host sed, m4, and make so they weren't picked up by mistake, built the
host tools with gcc 3.4.4 (except for GDB which needs to be built with
3.3, as discussed in the Ada port to Cygwin), used:
GCC 4.0-20050130
Binutils 2.15 with patch 20040519
Newlib 1.12.0
GDB 5.3 with patch 20040217 (compiled with gcc3.3.6)
Configured like this (output from the status files):
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20050219/7d59fcd7/attachment-0002.txt>
removed my /opt/rtems-4.7 directory, removed my build directory, built
everything from the tar files and patch files, and my build script went
all the way through building everything without my intervention and
without error until it died in RTEMS, as before, with both a:
mvme5500/lib/include/rtems/rtems
and a:
powerpc-rtems/mvme5500/lib/include/rtems
URL: <http://lists.rtems.org/pipermail/users/attachments/20050219/7d59fcd7/attachment-0003.txt>
I'll decide where to go from here tomorrow, whether to look at this
some more, try 4.6.2, or get a disk and install Linux.
Peter Dufault
HD Associates, Inc.
