Problem is CC environment var. (was Re: Something screwed up in PROJECT_ROOT or PROJECT_TOPdir)
Peter Dufault
dufault at hda.com
Sun Feb 20 13:27:11 UTC 2005
RTEMS is now building (at least it started building and has been
building for a while now) after I added CC_FOR_TARGET and
CXX_FOR_TARGET to the configuration.
My problem is that I wrap my configuration with "CC=gcc34" or
"CC=gcc33", etc, so I can modify what gets built with what host
compiler. For example, gdb 5.2 needs gcc33 while I'm building all
other host stuff with gcc34.
I just checked the RTEMS configure, and it specifies "CC_FOR_HOST", not
"CC". Maybe someplace in multilib it must decide to use "CC" as the
target compiler if it is set and "CC_FOR_TARGET" isn't? I'm pretty
sure this is new behavior since I think I've always done this, but I
won't swear to it.
Peter
Peter Dufault
HD Associates, Inc.
