Yay! for mvme5500
Till Straumann
strauman at slac.stanford.edu
Thu Feb 24 18:05:12 UTC 2005
Peter Dufault wrote:
> I did "hello world", finally, on the MVME5500 on 4.7
> A few "heads up", though. Take these with a grain of salt since I'm
> just starting out, but I think they're real problems.
> 1. The linkcmds in the BSP in 4.7 (and supplied for 4.6) don't seem to
> correspond to the linkcmds used to build the "mvme5500-cexp.bin" that
> came with the MVME5500 patches for 4.6. That binary obviously starts
> at 4000000, but the linkcmds put the start at 4000100. Maybe the
> folks at Brookhaven only use incremental linking using cexp as a boot
> loader and haven't noticed? Don't get me started on "incremental
> linking considered dangerous", you should see some of the vxWorks
> startup scripts I've seen.
> 2. bspstart.c is calling "initialize_exceptions()" before setting up
> Cpu_table. For me (and I hope this is how it should be) this results
> in a call to mpc6xx/exceptions/raw_exception.c, and that checks
> Cpu_table.exceptions_in_RAM as a boolean to decide what to do. Since
> I kept carefully zeroing out memory for repeatability before starting
> things up, that was testing false, and nothing was working. When I saw
> what was going on I initialized Cpu_table.exceptions_in_RAM to 1
> before calling initialize_exceptions(), and then things started
> working. (I assume that test is done before BSS is defined to be
> cleared out).
Hmm - this seems to be broken by 4.7 ? The code flow in my 4.6 BSP is
different:
libbsp/powerpc/shared/vectors/vectors_init.c:initialize_exceptions()
(calls)->
libcpu/powerpc/mpc6xx/exceptions/raw_exception.c:mpc60x_init_exceptions()
neither of which is using the Cpu_table...
-- Till
> A quick check of other powerpc bspstart.c's shows that they also call
> initialize_exceptions before setting up Cpu_table, they should maybe
> be checked for similar problems.
> 3. I get all my "Hello World" output, but the Motorola "MOTBoot"
> dramatically complains when it finishes up. I assume this is just my
> getting started.
> Peter
> Peter Dufault
> HD Associates, Inc.
