Fwd: Re: [OpenH323]Cross Compile
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Jan 4 18:50:19 UTC 2005
Steve Holle wrote:
> I'm trying to build the OpenH323 libraries and they are looking for what
> looks like the pthread and c_r libraries.  I've built RTEMS with the
> --enable-posix
>  switch and it seems to generate many posix object files but not these
> two libraries.  Are these libraries included in another library?
librtemscpu.a has all the POSIX and Classic API support (and a lot
more).  There is no separate libpthread with RTEMS.
libc.a iSoLikeCandy at yahoo.coms provided with the tools and is newlib.  I
don't know why they are looking for libc_r.  I guess some hosts put
their pthread code in that library.
Look at how the rtems-addon-packages are configured and built.  They
override the variables for the compiler and flags to match what you
should be using.  Eric Norum has managed to build a fair number of
packages this way.
--joel
>> To: openh323 at openh323.org, openh323 at openh323.org
>> From: Steve Holle <sholle at link-comm.com>
>> Subject: Re: [OpenH323]Cross Compile
>> At 02:59 PM 1/3/2005, Craig Southeren wrote:
>>> On Mon, 03 Jan 2005 14:34:42 -0700
>>> Steve Holle <sholle at link-comm.com> wrote:
>>> ..deleted
>>> > I get the following errors :
>>> > checking if Unix semaphores are available... no
>>> > configure: WARNING: This host does not support semaphores which are
>>> essential
>>> > configure: WARNING: to implement 'critical sections'. This feature
>>> was added
>>> > configure: WARNING: in PWLib 1.7.0 and improves the stability of
>>> multithreaded
>>> > configure: WARNING: programs. This feature has been disabled for
>>> this host
>>> > checking for pthread_create in -lpthread... no
>>> > checking for pthread_create in -lc_r... no
>>> > configure: error: must have pthreads!
>>> > rtems does support pthreads. but I can't figure out how to tell the
>>> > configure program.
>>> configure is looking in the -lpthread and -lc_r libraries for pthreads
>>> functions, and is not finding them. Either these libraries are not
>>> available or not correct for RTEMS. It will be necessary to fix or
>>> supplement these tests in order for configure to complete.
>>>    Craig
>>>  Craig Southeren      craigs at postincrement.com / craigs at voxgratia.org
>>>  Phone:  +61 243654666      ICQ: #86852844
>>>  Fax:    +61 243673140      MSN: craig_southeren at hotmail.com
>>>  Mobile: +61 417231046   Jabber: craigs at jabber.voxgratia.org
>>>  Post Increment - Consulting & Services    http://www.postincrement.com
>>>  Vox Gratia - The Open Source VoIP portal  http://www.voxgratia.org
>>>  Raving Of A Strange Mind - the VoIP blog  http://www.southeren.com/blog
>>> Check the FAQ before asking! - http://www.openh323.org/~openh323/fom.cgi
>>> The OpenH323 Project mailing list, using Mailman. To unsubscribe or
>>> change your subscription options, goto
>>> http://www.openh323.org/mailman/listinfo/openh323
>>> Maintained by Quicknet Technologies, Inc - http://www.quicknet.net
>> Steve Holle
>> Link Communications, Inc.
>> 1035 Cerise Rd.
>> Billings, MT  59101
