FW: RTEMS 4.6.2 build problem using cygwin, "multiple target patterns"
Bogdan Vacaliuc
bvacaliuc at ngit.com
Tue Jan 4 21:05:59 UTC 2005
On Tuesday, January 04, 2005 3:49 PM, Bogdan Vacaliuc wrote:
> Hi Chris,
> I looked into your cygwin build problem of 4.6.2 and m68k. I did a
> test build using the parameters you included below, and my build
> succeeded. [Not tested on real HW, since I don't have an m68k
> system...] I would conclude at this point that you have a
> configuration problem.
> The binaries for the build are all taken from:
> ftp://ftp.rtems.com/pub/rtems/cygwin/rtems-4.6/
> (I used the gcc/g++ from ./rtems-4.6-gcc3.2.3newlib1.11.0-4/ I don't
> know why there are 4 versions...)
> The source is from:
> ftp://ftp.rtems.com/pub/rtems/4.6.2/rtems-4.6.2.tar.bz2
> I'm attaching an archive file which has the output logs of the
> configure command and output for you to compare. Ive also output my
> environment variables and the output of 'cygcheck'. The last update
> I made to cygwin on this machine was early-mid Nov 2004.
> I use a couple of scripts to automate the configure/build since I
> have multiple platforms that I was evaluating RTEMS for. They are
> included in the attached archive. You don't need to use them, but
> they are how I got to the configure command line and the make command
> line.
> I hope they can help you sort it out.
> From your post, I notice that you have '-disable-networking ...' as
> the options. The actual parameters have two dashes, e.g.
> '--disable-networking'. I assume that this was just an artifact of
> you typing the email. However, if that is actually the command line
> you typed when configuring, you should try again with the two dashes
> as in the log output.
> I hope this helps.
> Best Regards,
> -bogdan
> On Tuesday, January 04, 2005 12:14 PM, Chris Welch wrote:
>> I did a search on the RTEMS wiki but couldn't find anything relating
>> to this problem.
>> I'm currently trying to move an existing RTEMS 4.5.0 application over
>> to 4.6.2 using cygwin as a development environment. Cygwin had been
>> used without a problem for all the previous 4.5.0 work.
>> To get the environment started I upgraded the cygwin environment.
>> This was necessary to support the newer RTEMS cygwin tools. The
>> existing environment gave a procedure not found error in the main
>> cygwin DLL library.
>> I then tried to perform a build on the generic 4.6.2 tree without any
>> changes to the existing code base.
>> The configuration (not significantly different from what was used
>> with the 4.5.0 code base):
>> ../rtems-4.6.2/configure -host=-i686-cygwin -target=m68k-rtems
>> -program-prefix=m68k=rtems -disable-networking -disable-posix
>> -disable-itron -enable-cxx -disable-tcpip
>> -prefix=/cygdrive/c/dev/rtems
>> The make command (this is just to make sure an existing BSP can
>> build properly):
>> make RTEMS_BSP=mrm332 SIM_MM=1 VARIANT=DEBUG install
>> The problem I have is that I get a make error "mutilple target
>> patterns" from make (v 3.80, same version as was used for 4.5.0
>> builds) in the m68k-rtems/c/mrm332/optman Makefile line 567.
>> Line 567 is the instruction following the $(PROJECT_RELEASE)/lib
>> target:
>> $(PROJECT_RELEASE)/lib:
>> @$(mkinstalldirs) $@
>> I also tried building the efi332 BSP and had the same failure.
>> In summary, what I'm encountering is that an out of the box cygwin
>> build fails for the m68k efi332 and mrm332 BSPs.
>> This appears to be a generic problem as attempting to build all of
>> the BSPs fails (i.e. not specifying a RTEMS_BSP target). The same
>> error is generated as soon as the build starts on the dmv152 BSP.
>> Is a different setup then 4.5.0 (i.e. any file tweaks, custom make,
>> etc) required for the cygwin environment to build 4.6.2 properly?
>> Are the dmv152, efi332 and mrm332 BSPs (or any other m68k BSPs) out
>> of the box builds with cygwin now faulty?
>> If they are faulty what is a working m68k BSP build target under
>> cygwin?
>> Thanks much!
>> Chris Welch, Neumes Consulting, PC and UNIX Solutions
>> mailto:cwelch at neumes.com (613)797-7831 FAX:(613)838-5602
>> http://www.neumes.com
begin 666 010405-cwelch.tar.bz2
M0EIH.3%!629368[ZMBD`\4Q_MO__^T%____[__________\`0 `"( "&```(
M8*G?-[[WMV^N>65W;SWSSULR5, at OCQ\7GKT'WOAZO?> `/-]CSKO9KLZ)%54
M\S!/N $@H #'7K$E>^>>0:CQ\]TYW>)1Q0!T`>E]G*0A;Y&^#E!($$H```H`
M`56/O.V\F^^GI[V:(@!ZJW:.*+9U?;T>6O6C:YG *NWW+O=UKZJN70:K9[/O
M>^]CK;N[MENS4.=W9O<^G/K[SP\H)]94$"A*EJS53K++#[-21%7 `)M:E59B
M[.NJ>!MT%5G,=4IL:JY?;#ML/;+NS<MN&\NK@]:O.KSO-Z*.I>?;JY;>`'<%
M\9ZZ"=@EMN</+WO=9U*[JJ;N[;;[M[V^>SM5;#>=5.D\6.)3?;@`7R/L[@T^
MVWWQZ+WH/MVSCK1HWL\ZVD]VXG;7;6UJYSCG<CMWVUT%):I@```#3>[!RT 7
M'T[E5*JD]JX]'N>I9:M@&; >^SY/>>[R4?%K[>]NKSMM-K+BT[KO>>O@#>.^
M;,6:UANVNT[N<+MMEF=M6K&.W<Y#N&FB`$! 1J8`$T3T3::1JGX4\E/U)Z9&
MB/1/4!IH-&F3$: ,0:9 A":$:3"-2::2?JCU&F30`]0`- ````````$C420A
M`!3"$]2:>D\H]1Z@/49-#U&CTC0]( - ```#U !)ZI21`A-,3*;1,J>F)J#:
M@ -&C0- !H ``````"E)"" (T 30$::F)I,F*GIZI_J4_0:H_2C)ID/*9
M/*9J: `,"HHA`("9- 1A)D&DVFD])D:4\T-)M34>FDV4_5/&J'ZHPT1ZF-0#
M)O]P_M?___D_9_[?3BX7[Y]<L[]S]B+BUQQ$F.4B1;$'OJ-OKK[/Q?B^S[&_
M?4!HC=:6SH-1-7 at VQF[B8]A)MWP, at D,"0 02Q +,"VVO at W:K+;;6\:M!JH8Q
M1!E at G^O_MU#_;7E7MK^=S[=:[?97DU9NS6G*K%7JY>*B!- ]9"?[(C01&'<.
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M!!22())!4D<*HQ*E2 at 0UJM+46D(L(\N_''?AQQJ_"VF-^B,!>IV:@MTJR=$P
MDL'97:G:LL9$S#;PIMV78&$IS[F7GEF-Z3K7+*U2EJRVZ*8JNH4 at D%2"$"$*
M+"8F'C$`O$]FR-^F&R-7X6&P7X'ITPUA(_2GH8XO1\L]$E<O at R8[(*'Z1HY/
M[3A^?BX>/CTZKMQY=@PMB^,MA8ZLS$WTQ;R6F<96I;>MC;.(JI+:),JW%=AO
M>+6*BX:!`:Q$9!XS%PU"SRVEIZ3A=.ATTO)BK%<E#SJLT]0NNU5N-, "':B6
M``# J<65&*!2B%<3%240R5O9O6TY<^-W=EV[,=G9RD3,B>D[MSJFC&&-LXDD
M:HVLD]O9J];EBBVU5#@*D$N$`I%Z)XLQUB[>U<>_IOVQ<_TS[3>@L>@H.#3I
M[TM]UFH^,>ACC\_]??_=G]5_TN_7>G7 =5$A2B!$1"4`4(GA1 B(,.'N4"'D
MQ]OK<W^,)&*^W>Y17C)KZ?,WL;'U<U"1-;K#TTP]CGU1`@`ONG>U7+&!+24W
M=5IZ>9NRG1DI5E\Y4&:>Y40YI35Q$S0FT'_+$_FW_:\N[YZ<:!!Z:U(J8Z4X
MN0=Y0XJ\(V]9.:]7LY7/?J #")?",R_7NR7V>+X]X#+3AP&QWWT1F/8?4>XO
MO_;)WF.]RNB `[Q?.Z?DRX6&3>9[![)#CI0U/*<#D7?.KSM/(=AUY!><^P^4
ML7%YU':><A\UV:1UL\]I'G.!ZSTG\DPNTS.!\!H>\_T'`Y'I/.9%YN-"X^ \
M98MRK,\&2R.L^@YGUECU@]IYSPW+N+L;G\P?<P=U>4>*+.TM_,#O`>/YQ0E)
M()$$73Q<JS+V:@*9B-H30+:FE=8Q[6;7=DO8J4IE&PMB)O])TP&C*4.J9<[W
M2TN7J\W47\NS<+=N%]5-N5Z\NE_9TG5SG6S3H at Y_$DE5_:,1,84*]'^6K7UV
M8PJGRQ15_6,1C*13^+"Q92BKLC^.?AB%_CZ,++[^)?TW\^EZZRLK!E8W^_\H
MOLU^.K^C?\6FNT8E)3:-MSFW376Q-195W<2[IUMR+%];_Q\FM9M?\Z[9;-9K
M+5S5N)F2S(R956/O\=.A'\6WIY^"N(?Y?WOX'?H*1E1@`'D#44"9ZT1]#'XR
MI>0MV;..'6H'AA]SW2G KGY/,GO098R]_RTU3K\DTT9DE$!,M%]G'.D-&>GV
M_-,;GR(PZ##Q1?R_7\XY7"PPTZ&"`2Y9,20"EJ*!5"D(4 at N'N at LU/T%.QOF^
MU0,8E%M9D0U<R,@/BP;EG+#W\Y<Y2WJ7F7F!^NO."9:M?:USJ#.&C:S3S]4X
M_05CO<$YW70M#M>!D8$$%)$*4;&TENN@]<5?R3'M^@Y<VO*?+HT7J-&(N(T'
M20Q#B QV*H<^S"!>45RL0_;RH at 0`<VG[6O*_X:]O5;7$Q5YF=;<6J/1?7\UJ
M<%;IV?@["$(QMO/,.M'WPZ(9+&[IBU+EO-:NJ2=,:K7.!$JTNGCUA90C!\-^
MDO?%AXM_$=00``)L3*OAJ1^&55DM'UT54^Y9FR%DLF?X5SK,+KN7\>L=2 VG
MG- at WQ%3\?QM7;X6_&2:HLREM.;I+-FV59K%;02,TQ*B6IM9E9-J39&5*:DFR
M:5(IEE:6DRJQM-C+`S.P(4L\P;++08+*RU42ELEFDBN79J[\?+QD9$VC85MA
M<% IAAGK/F>4[PNGXQ>\BF62SZ1BB(4_'6"(TKF[_)^7F9F9F9F9F9F;0")A
M`E!*@^0"`/>&J#NP_\#_(OOZQ&?.4B^%,C9P!Z9"_;H+WJ>F4QE56,S%3,PF
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M?[WETO=UJ?IO]_73/+C7#<9)8_*M*FD;SQ at Y^H9 at X5+A;9#,IF6<,Y^_7%4K
MC62S-?!KG"@(`"(`YRC 1 `$`&OV?=]_OM7O( _96 T7=]JQL22F`\%H(!(B
M$B42223;;;;;;G&,\GBB:O3\N,R1VWY79ZH=(J2-6L6HK4 06R )) U:6JS4
MVB:UFVK)DUDN_=UO##1H(LAA4V>0$10[#61>33$V"! ?>B?'][M=7=]3P!O1
M3O[[$B44'I6;TC#UP(LP#R3YQQ3#( _^"52CDD557!@0,NPL@;W!@"&!_1EI
M$ 9+G<%-P4QPP_1P0+VX`@U">Z/6 at 1$^HA$0!U]AE<U7)@4XV4(7HJ9J>9WM
M$G&P[7'$<?W\"V<>'3?Z43^@1-H<=O:Z=KY77]['2<'"&J?BB64]^4Q@#\((
MU@#7\W>OG\OG]01E_A4?"$?3W=JN^ F1O -7^*MR0)5P9/K9WZS?:^0O+Q5X
M\,WBQC$+%7F)_21TWCY?>02M6K5JW\/R?2&/QHF4T^SQR&0_K#]*@ * H '.
M`.8=*>8<_D\G7#P7")+002E%"(-%5DTX))))$/^=(Y2JLR2LD2D2$D) +G"C
M?MNW::YG$^VHUV+5I+NQBR.-.L[OU3 ],ZX^SBK3KS D?I=">A^T'B1S;]V6
M<0*9[J7[4MOC^MHA<SLOSNEU\/=SYRN+)#7EC,M3L-WE]*'3;8Y\?G9T\C\>
MB)GH_J<U/,I5,J95F?HPM9?R1^5F0_R;]?X)K)7FD_,/T+0)%D)M`NBAM3MQ
MAF;T)G.;ZS-DOR/F'^7D']=7[C*KU1VY_9GJ/&E-?7<?'8/DR3O\.#]N>JZV
M6;S?IIU$$RXQB_AQJW/5S21,ON5PXHGK];FXSKY(FO;_MTVNK>[9#C-W/IDZ
M&[L;ZTF=!I3IKV8_5NF[:3YF_GQ2=UG5P?C!Y[99)H'%OQMR\M>=\JF]X=,4
MY>KKP>*. at N38QSSI0. ;L]-M>ZRR=G;QQNPZI' ./*(:\2L$%/C37T."%P=&
MZT8Y:--8V_T_VS.'-$WO7T1,-^G5Y\>K311TG>'<AGH[(P=[*YYZNGD&7GXO
M%N'33I6;YQ4,(522.%1 X;G#' K2N5TG/6]R)S1*]^0WCTYUU<M3*6<9OX/=
MM7.Y^'CSS:DZ`[9G8UG2<=+EL\^FR6YO5?C2'B^=7'];Z72\VVW"M&,48HHH
MLEH+8K_TFMS5\6US:*VBRSNYL)FHFB- at R>GGIGL1.AUV=O9_O^7/I_=O\GY\
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MB([NNZXB(B,=UW=<1 at B(B(BOY.Z(B(\[HB(B+Y7O?+Y^=\_G[>_P1?'KB(B(
MB(B(B(H[NB(B(OA>KX?'SOC\?;W^"(B,0?'NB(B(B(B(B(B(P1$1$1$7NJ;Y
MMYY$%I:6EI:6EIY_I_B55555555555W2TS=JJJU]6.*JJJJJ]W=W=W=W=[>T
M1$1$1J(C!\>Z(B,1?5?.^7U^=]?U^_O\.B)/BZ))))))))))))&"(B(B(B(B
M(B(B(B(B).="^L>I145%145%145%14<2HB(B(B(B(B(B(B+Y7O?+Y^=\_G[^
MZ^"(B(B(B(B(B(B(B(B(B(B(B(CY]W=T1$8 at NZ[%$1$1$1'=T1&D(B^;?-SQ
M$1$1$1$1%$1$1$1$1$1$1$8 at BHB(B(B(B(B(B(B(B(B(B(B(B(B(B(B+Y7O?
M+Y^=\_G[^_QZ^*(B(B(B(B(OA>KX?'SOC\??W^'1?/KB(N[B(B,*M6NN=090
M]IXHGY at X.1# ?)LY!Y/JW&DB#@'/M^.-9ZMD]>['HO)$NTVZMKQ9B"<W>%^C
M>W[\0XK$[=-&OMDUY1=9QPT=_?N+TN6N3D8UXATJ=Q7!W)8<9VF3*Q6>EW:P
MU-;+AO1+OWXUAJ*(),<NV[Y/IM-M! ('])F0"+%TR5;&,_/?(JW8W6WLH60H
M.UPDX]2&[]]/R2UV<>#]:2_R8#P[O)+$7:+N2Z4O^V8XP^;P>)UKN#0="?\;
MIS;_G/\1IV2F7/V-6VV4RM!A"ZWZ<2U[?SAGER7'/U4 at KY(D+ZO7W?)CN;^$
MZ;V"L.7/S(:4BOQR(-">=[M+XIUF8Y$.,)$^.[R<-KL'>KF;[/?^BJ&5EF4F
M9*V>;_RUN_+NG@\U?3_3[O^GE_->W,_P^GGT$O&9!+)_BI#]W]?/$\WX,YI&
MX1/)O1EI_7(C%!/\^V:"77_!9E?X:UZ\SA+NKSUZ_TN[^G<?^=@S/\*S_+Q
MMC.Q*Y8`U-"?12GC92A^S^O^7^.==?V?LYOQ>Y!M]0\M_2H./V8,GP\O,&'1
MV.ZL7]L)/E\30%#"=WM#R]?#1[_$)Q K3V4]&,*?"4ZATG]V%T1)?FPBE*5F
MS/PQ^2[VAYC9^YU5CSVF_-9_7C'A";C-ZZ#N$ULAD0,"6P!@6P&6Z-X;0\#P
MU:)L8&@SV3Y#P.6X%B;YAX.O=:<7%R<)AK.MO>#9LY-&9K-'*9GA+.+;=;/"
M<FK=/"8<'@T;W at P8<)KQO5A3NY=8=QMEX!>)/G,T[U4SH.5$:"<0:IYPZ>6I
M\F),SY;1HVN5J\(T"-M!Z,AW3U01MYFTC(-;+I>^XK?2W.G"R)W"WG0MZ0$`
M8:L78<JH..^<&Q5C`T/$:'<2'&U\QQY5KN)[^?3)K(X.<3U3RT at A!^O07711
M<# Q(+T!T'4>!N.!N*'@1%X>*!7BZ3GF0?71@^.8IGGE8W"J6&<G at EGU*0.E
M\0!#4%Q>CB<=,H;!;"ZGQN^^U5&[GGFM<WUGJG4%ZZKF,5.K5&VF&II8Y)F=
M&(U3ID,E43^KVC5^*4O5[*.Z-\=3-KKC7T1;SY/ONSF_V?;_%GNN^KZX>N=P
MX-KH>#P=_+<RG?YU6&[1J]&/0OHUTW_!?34E`;U10$$4'/@0&R "; `GL%@N
M8O!9Q)VU.RQ=,CJXS*-EJ3L$Y$PIQJCS%^.J.9,HS[)TZ?#7+)RLSLH[:SLY
M_"M><[OWJ_CXY[*D?QWP(A*&3,S282R6*4,IF:S96RE02,K-2JM%MJU at 1RI$
M.,6$?DL2=I'82H3T5[^G]00)^$#HFB9 H$1'_;V@,4WN/3M)(V/.VTPP-S1\
M7G9FI"E17J_T(GY_O>E-7SUG.#'U20Z/B*62?Y3"<3),$CE8G")][^/_(W>,
M-_GZ?\B\&+%,9"K,I27.IDF588+#!9].OZ]Q;BK*59+:S6UJFK&ED(0A0@%"
MQ4(`G/0GNVD][ X9\(W)V:(F/7F^"%\"HF;&,YB/U1^Y`_6_-_+#R )CVF(,
MD,)_%0X$2A!G\;<23]1A_K*QF7G.1&;P8T;IT1$M(=""L[Z:(6LAQE_"V%E7
M<.Y6VV)@Q!@LD_'[H ?0.WS_3LUP(?\;69^ODW;^`W7 at F+SE=Z*Q)B*-&E U
M#"U]:XXUPQ4F"5T:Q:]-`$+P00;@%1(@:0- F9 at D>?I]-\&4'?!S"4Q8FH#_
M7/A=GZ_'9^O!42L8"N\6'B'@P[,,M+E(`S)S>_71PTZ\LQG<6906<1&,2+@;
MDRU :]\DDFB!`B (!2X6)*SLE#514'[WBX\O1NU>?Z<=/&YAM^^:3K1\*VHU
M++:YW*,$YHBPX,]]PZ0``@_(G^O52#;\/L0;42?2$\^W[?LUK6F\2^1F/TU.
M:I4V2+1'\F\=GX5_S)97+=F=_&K:J7W,8F:*V5()HB-KT+QK"%;L<I'G>Z.1
M?3LS``1,@ ]D0*B8(G+ at 3NX34F+BNG*07FIRZ2,VB@[(H,G^Z92!X#EXZBV)
MMMUW59,J`Q8JS)3,JS*LRKQ;[\=U3OW[Z[L7$_:R6&*6461+*6$EA,J[*W*X
MZ=B,J[JLA/?5J5-2>';UZ]32)=$H+ZT;CO;UXA/^K#,DFB95:R'_78K55DLQ
MF*QI6JI-GR)W#G7G)O7:5VTM*/]N%ZLIF5F :REF5K1JMP```-M<VU78S*DU
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M-5,69K2VF[!;1 at ME)6U+4EM1:E2,:M8LF*S"TRBU2T:QE+5+(M9(RLK)C:)D
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MG?8!"9/',Z[/0',FG,C+.W -5;G:]5#3M%>E+EN\SJ]4>V69RFG+U at TN9'*4
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M#U=9!J<9%UBOM@"*4:)B:70>WFM:-JVR at Z05XFX6-B)A^#]+[_ECR9/B5G8Z
M4CA<9>"-NZH['3KF'W\G>=%<=:<=Y9"L1MO(J=WOA>NUWU2>=&".CN^4J2Y/
M:B>'JJA&PI$KW,\R.T7=2(@H[8YKM34]+2U+0LN^D.7Q,&74PRM54NO^RZPD
MI2"2KTEY""*(/7+YW06VK#B%9"'IKGI%@N<^(F<;Q]^U;QH=SGIQSSQ*MT9T
M-&,!GCD->D50,&8;`^X52E&C>IB$$<T`0)0DA*4'P 0-X.PC<%2?`JD.(\/"
MP#<2O8E3!W<6/SN%B0Y)(<,1$RZF[\)3 at O)1))1C#P8]*@1]9#DUG21*RG+X
MZ'F=/C$<3C4T!!_[N%;#C=ATZ;AZY<-KA;\\H 2-QA<,D0>0(<8@* @$6+ at R
MA3HB'V:X at S*Y*H,C9&#L8)@LRP@*+>/L.OW^OUGVJJJOP>Z%/53="JJH2^/:
M\"/R>KOZ^OY.(RU9]A =^!73I550JJH9VK[/S''VVGWNEHSNC;Z7.Q<>!;TM
MMNPEJO'$P=FUL ]]0V8XX8/>8D2B]^#Q'?O7GN5\=NRK"SH;+P_EI3*O,=^-
MJF+PK\]N7%N5QH+)<:Z5R):P)RU2AO82V.NVQKF^^!M:`#R"6HL77Z#BNVD6
M(OB+7WW;UT(4G#.;CCO;\Y9Y:I; 8PM+&NZZ`<7:,59HS:>R\ML:>=-K\H91
MS:<IC1!V+UN&&4LHB9H/D>E:F39"^/3#C48KI at 5\<3QM\'RO><W&WHA+:-',
M"\%#VW=YX[C?C:9D3,SLA%A\!=1#N0]L7UE&U\Z5%H5E:!45>'2"O#F8O+H6
MA:$;6G2PM6T?`_@,1^.SL!OU'34[/$Q$Q!$O,R) D2)$B9$D*9F7=_ST^O7A
M?3MCRJAG'>3,YL04*D_2H^QV&,--S"B'(S#X?RFS]Q[.O2'SW=YV*])^Y/Q/
M1QT]O/,"*/F.\=>-Q8@/SCMWD<7 at XPO+(V?%];G $:W>S=Q$0O!^.GM^6:SJ
ML<=CUOK,#R53B>2_-+2</&#ME1JIJ3>B_R-<\^7,]?/YZ9SE]^5SQ;NCT!ZJ
MPGZ$>>(BGQ0H0RRA+I>5W&C)'J[O"6G^P^GOGSWSF3^.Q/5ZJH1VAT9#H9]^
MS/?:Q$8?`Y-N)DHQZ]N'@2V-CAY&?1VM\WD8%;7O;^V/1[:UAWW0M]I at R'[/
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ME7O+R$$40?++OGR<+;4AQOFN1.-0,W,0PKN%L<,EBVXASAMSQK at +`L+V4 at 9&
MZZ+E=7QF>QE:WVR^J at L=MG%&,=_)]Q6M;UF9'.]<8SSF0Y 0R-XQX[7UE(\[
M$A0,NQA;&>J$NE?/$=>/.SSJSC%1;UPIT^UQ,.Z!>R%Z(:SVG&]:SI"MY?F?
M;,YYFN%@:"]<"8)0S3GIWVJ2'=WI(@BD>F(&TT9@/O#D;XW@;3AQJ,NTZ=W+
MG=X#K.,0'?:0X?=U(55U;[<3>%CCNX<^(??#N_%/R<&#Q].V!B=CZ<$]'F:4
M#1/>F7134OZ>RZ0DJ2"2MT8)"*(.V7S$$.Q/DA/HJWY$*/L\DX&NS^^_O]?J
M'=WJ,?;E[N\7X]GOD2W;BH]:7<1\5'I.'"('8^Y[]OP](:Y])7T].)D:O
M4F9]1Y>!MH656<+YTG!F[9["3D5!\/1V.SK:'OP[SHKK]MXCZ^F7'TE<:T($
M!]Q73F15F[77`JN*[8 C.SV<W$1A?0^O'T]YK:;Y^#Q768'=5.)Z%^E+2</&
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MW''#1F-&OX?NILT--33*-AN8 at DEE"F];8=8TMN:'*0"ETO(=='+)EF4P,&:6
M99F6N!,L.%G;)9*F4(# `AX+A@!,Q]X<B7-HXML`@A8>[ NW=%N:8K=)5C<W
MLPV&<S>;]&(U;M3L39LVN,X!9.PP$A8'.H=0YEP.1Y" `@C(?UA.+5HI?74O
M$.:7%)U5Y=[2Z?7OP+.G;K:AH_ at R!<D7\BTZ)SB?#.#P\&@H`\1"<+_>B/BA
M*$I;+8%LGW19-I^Z'HSV^L.J9&AR at X#/!,9A)+;;(4[228F39]R\O[WY[NON
M&' GV7!_PJ ?9]F#LX\.9WNCJRQ,U,._V=NA[-BN6]K[_;M&DK+:VM-2TNV2
M at M3;-&M%),*5.(VV]N:>5\>%3Q8UU?T?P]6O67KL8QC4;]2O7G8QO%>J][XV
MZ\[X77NQC&%+B!(B`<0\($6B1V3J\5$GF#,SFM ]];1JF\/I;VJ?73J^C8QC
M&,8QC8QC&QC&,8QC7P^&XS*SZ)&%( V=0D"!0X!=L$RLXL@?=T_X>'D\[Y?E
MDX<G&:D/`SF:#.;DRXW1F8)W:TKMS&,8RK^+J[TJ_B]GJO+T[&-ZK\KSKS<S
MJ[<QC=7=C?J7T6? @$#6;\LZ#8V6RV-ELMBC&RL8W6!M-_0O/-]GJ\\RK]?C
MRO+Z.QC?2V]OUX]>L8QC&,8QC&]*YC8QC&,;U9)M/MOO#: D+"%I)"VW[*3X
MM!4 at K) !62$:#9"!&M))`8TM8V$$:C^M&&8PA]D+(&8R156$0:@V0>Z[G?T_
M;7GJWN('7'[[Y_<^F,8QNU2 at .^EVZIW;:G8QC&,8QC&,8QC&,8QC&,8QC&,;
M\+;6V_#[/;NNW9W==QW>7B_3YW#^-SQN&M!Z7#?O``'Q>/W#F^"^2]+T](Y>
M/!X"YO%[(@"(@B(B(((B(WL@" B("#$1$1!&(B+TO9>.100``8"!U?G7VMN[
M7;]_X/IVNH=N at TCY^,GVE58J>>^GM=N8TZ[+EV-<QL;Y3U]-[\_8J6E2^]D5
M)SPL,++"QBPLE26+%ELL6\56Y695EA98LL6,I6S/'8<S2XR>=&PL"0+#>!%J
M02<PF$M)<"&4PF<0S1AHMEL2V"9,&N at P<69)-\B6P9NC,%B-M#4C6Q;;M2L8
MFF P48BBJ*HM%4510HI15%DHLHJBJ-,DQLF&U9"F$LD-K,V9[+>'%.>^;XV^
M/QQO?O@\QC&*^X\_;J* (#!B+/OUK[ZK:U[7K>EFK:624((#66:WOYO2GV=;
MSSYVJL<DSE<'P8UELX%5T=;#3E=94L[;T].\QC&,;TWZ&:98&T_I?36]>L;X
MW=O:OEU%%%%%%%%%%%%%>5>>=MO3UHWJ_1>!%51;2Y>9%90R at A4:PB%I2F%6
M)61I#2UA8L46*SMNH47MZQC&,8QC&,8QO&,8QC&,8QC&]R$Y[^7 at 5J'J)QFT
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M0YIK6;N<F#2FDHDA3Z.;`#(4F$20V3=)(-FZ8\JJ;,AEEBWEENC&RMEIOCC8
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MYZOZ=.Q$`Z?();[N:,)+38B!`!"KO'97%RLK-O<'AQU8OM2MM6+3D8<3GIDJ
MVV7.01+M?5_*:[#;KH8[],S4W:Y6R=GT2(,3_9_K7^]C/]^?ER$%Y#OSS#4*
M>-20?R0<D?T!?U6NCB MYZ"M\_3ALD `I]W7<3,5555?<>LI]K\TE^<@?7^G
M' MRQ'8^&=/\]_9AE94V5;%NC at F0_99 /T_^O^O*/X=S%COZ$X))I4=4K;J[
MYD'\`0@(/S6GI_)ASQ $A_E[__M?[6'[_W?OOOBB; @L/BUZ1 .3KML55N[R
M7X_N8TGL5ZO#DGIT2'%9"JRLJO#'=ER;=_VZWZ/'H-JHQC*Q(W&YC!+!MQY9
M;]SD[";N&]PY;;]XQIG(WA49$#<A@#)>"P=M?6-HQ@;@?J,R`9JD`:XDC1SF
M_=!:B-F[].-NNQ6S$O5(CCK;:2269GV?<<:JU5"SD 9H,. at N:>?P_!NT5C]#
M at 8;L:+X;7QC]RR3PH;N>$2V1'U_YM^9)M4420&\)F V8G0'[V;Y#>X4@!L<B
M3 &2W!23AXXUKSUW<VE7."IO85')$&FB.[[?U7Z3Y/]]_^V7=WW!NZ>'FMWK
MWDQ:3XN=!UXO>X-4L"[^QDE&0PCZ+/,4=&_"CKH+78U'O-5H+JMF[@X=[2 at 2
MP("<A3?J8LRJ)EI)K;XGH0LEC[2U/;E\^4.0ZK_9L>_HGQ97Y)]OZ//<G'=G
M^W):=_G=I.C_T?D1B9D9<_AOX+^S`U(E-TXSOY'CRXY,[885HC[W/@Z^U<2<
M=QB<OT.!S.;8LT)M&_NQXV'/MY<).4<<%I3=NVL_B0\,2.'T?3Q?>XG)U-ZU
MRJ7H::ZM?N?Q29D9^?683QOCPDYR2&KKS^"3:D9QM>"YL,W?=HW/YV9YD+ZM
M"PL$SOF\&R<\H-UP":2-IR*!@0A0O)90$8(3X5_MD=D9BD>=-^_/FW-,9\WA
MV^O&==VEWUJZ'1 ;,($H`B<!(*CW8S<9*BDV>QK$:-YXQ02!5;NY=>B/5KPR
M?-I at _E^K_".1`/WF(PSUN/V:>$X5>#&&.]\O+ZMXIIKKZ<HS+_G;&H#($";2
M##A_3\7C[?(%[>YSY-T+4O\/FA7NEYY/Z$4!<+_%YW=_H*QR-2(*S3<KK/&+
MN?N3DV )T(CP=8(Z54 K1DPL_><+_&#O.]E+/%B]NNI)W ^QM+4=8^K?A%*9
M69)1E!D1#*Q8Q84%E53*62X_@?JY2^'+:/TXLV5?=?J>6J\&D60-5?C^'Z7G
MUDD-8D,=1O\/9Y65N=UEGWJQ'EY.QI-/#P7M(&LIQ[ %'A!$)*B0`>D0R()1
M%8#R1J+"0$: E at T_J&=AOY1(DG (P, 7P\,X*'[&0S&*4W&67#C:RQQFK5^J
M\>P)?J-/TODT_ at 1^K0`F at .0\:#RH"@LSU.L0S>VB'*&#X\]$'X/W)/O 04M9
M3M+<%7N#BKW">X(@Q'X/NL at C`E"0-J$%" 9D(BE .WQLR6'A#F<0!U=G64(5
MAU,3![M]?%>!PBK>M6$L9=2#X6$JEJVED'@U+SHX#;I>JJJ#Y(<((J21)Z#H
M3'6Y*@+$,^7UO16Z^'Z-U ;G+$-$RJ26OJUP4?V\-\Y.O?NY6(BD401/F&GX
MN.]-W+BA7D\]H)^_=KLY6'&&8EN J/O^^ BH&Z]&8 at D!@OX!UA$2'/N$1=$8
M,V-6QR81,69#$Z?%@&E"96F;OU<=S%RU.OTU-?S10>%53E\SKAK,U%N^L:2'
MN7_=GODI9I3%+Q55XOPI$ '\; <_=Z?=V>%U`.(3M.,(Q ?-CZBL_B7Y-P0)
M) B"(P2_]8EH>U_-:/ZMOG\]M;MM]."^-4?)ADR8PD]//3[ _?U)[\CPUK&N
MJO6\\\H/4<Q"`($)E!&4O9@@'(H45FR!X#N*1,LLBI?M0D?,W<IQ]]VO+7?,
MCGSS=]NWS$T7<X]#^[]&`@-X@(9+`\/B'X9A#R' <L[@)9G%.(;N!WWW<W%&
M(LHMS+R4WN/M_#J[_)M9GQ@^,I;N?B07)P(G&/(4W/1'S;?W#KXU,8B"**<P
MI2+#BA&M(WJLP&VDF6GITFNK76N.IJU'5F'1=MR0^[S?$@1!M$;\`$OG?>HO
M./@+K401# N at 2**&FX426_]>GQGQ36G$<]\TQ)G:_DS-8$L^/\'EEO]V(0B&
M^A$]]D_']/K_-^_G1F]LD^:_:^UXY]C37376#T'..J//98_S9MIH>/['Y4D]
M[X<"O7[V<9;\_5T9].IC=[F_1G^_[<MG(;<FR$3=OX9S)P1B8WQ-9F&O1XQ]
MZ,B\6T7\RJ:0TJ<\J**Y<UYGK]93\2JO3[/R:>7JS/,A;;?C"4#@._>@\HI$
M4$(1<(S[^K(^V!)(D6*(@&LN540`=;,V8#@H4=/EPSZ7P-CEQ8\;BK::->DG
M7:JJML6+)ODRT[G9WZI&^1+Z*66XQR^)4=R'!< %ECS7U>?04_%!%A@>H8!F
M9<"5]/UEOL$)@KA"`NBZ")P6H<0$F<M!=%W2F:+H! F"@$2H!C);F*,0@]A
MLF*AY&<C?3XSR\,8Q+;Z:FF;`MOG\OA^C[OZK1SY\*S#`U8D1OPPYY89L1FL
M-P;?RV7ZFJ21=<(+O<.6>YRPY=_A!'Q<"-"!W\B2&=_$7.>S,D at 2!)R0FG%5
M=E[$SQTRF;5BZ0S9,5?)>'9C$\%#7=++:@J"RRZ8ZL/+LTN6^F=6ZKQTVSRL
MUR4A0JASXAS)0CY0"DA!3@<),,#.GV:/F0^_W?S_9UD[\8^_F[-WV?#_,+AZ
M?73YZUD,)BY !$?J0 !$%Y0`!$&L(6,_.U"Z)695/+GSV1Y<FN3'5$4`)R</
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M2_[GU]E][/-ZT;U!=_B=7N'^_R?X_I)(FC+['^/:XN!-6FCO1-%B at 65[B2B)
M:..?#Q:]6D$[?-]Z3)#];U'[S\3^X[@`/:ZZ[N/0/Z]YZUK;SR[5FF<Z8MJQ
M;;;RY?K)W?)?,QC#,,.^(Y/YR9SLVMRV=--8(&KRZSW/!CIHZ50M4ZDU)V-K
MI>K><CZGU.]OF9?!_ W=+K'@^9,<7HF-(,8PSZ[HS$X1[W=R1/ T:-+Z7?CV
M/7F>\KU:BZ^CMWJV)+G4%X/II&UB\O>R,YRS(CLCNOOX'BW," WO'OMRPLC#
M,'-DB)[N/@_@\OQ-H-_IOS=ZYYZ4]"Z8T[/M(FC9]CO>3AQ;<-VA$3BNF-.-
MB3#L^>:>3G-[7]'4Y\;2/"F]!$RYL\8X41/3JZZNXJRVORLB)@=K>[7&'_(_
M-V_R6.7)IJKY_F?7>UZX<BX+H)>%07A+U<FXERF!+M__$FA+N)+VP4^2\W5?
MF=KQDY/PO=Y*A?>X^YG5MJGC^F[BG-\9]CFKN+YP^E_U>-F1=!+VWY"!S=.I
MYM-B/XVG^<QU$NYT*<Y\7%&J at O6L<N78?TO+V^KV5!:VK;7NS(R]$D"685)4
MWP:+M;7;]>V4L\TCE#\S]7XU#M>XKY+R8\WT>/827S\]-*A<#(]DF\FY7O/7
ML]3Q?:6G@)=:=LN$P4N[;L270>IQ>50^U^;N>:Y4^3QW7@=UW/.3O='ET_(U
M6ON7\KW1)\QIZ1 ><DZX*]+Q:3+X^/A.NGDT:4CS$C at W_+\JQ9Z)%D<UW=6?
M5?RJ^_Y[]&+[9._X'*6&4>G at V;GK>5Z>QU\Y/Q_<Y.A>L['?`D<_<]M?),X^
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MFPD at G!C)WJ>B<D_6\3KXRMW:X=O)^L2RO'L9>#=]':M'8CD[)E^K_W]WZNGF
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M5 ')NX^+),+DT:MK"B4 at P0;16M!$!$F B8W;<]KT> B;'-N:ZL-\B0GK,O!Q
M<I4-Z8YQ'11L_*<L=ZWFSE_U,R2)WNI]I?C_!QFM<^^O"GML:GO'__[]+\U7
MO;<$>JO%_$[>.9TGRQ ZE&DWK+.#5Z%=CY(XQLZKGV?*?.G1X%/M<^?\/LZ5
M,V/O%Z&WF8YOASS(E]*@MW@\C579_\,2\2\3U]KZD;NH_:(!W-=5^S[-8.YV
M?%O>\<$D:\HXS&K+KP_4:80_ at I92/,D>9WIW&>$&><GU?PU!7;(?W_U3_"J_
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M32M,Y<MQ6W at K>-56UM5555<N6XKN[;JJN9G,RW%;=5MY:J\YRW"WF&85JMTK
M:JBVXK;JMO%55Q5546U5%M5=N*)F9SMVE*6UW4VX7.C$M145%2TZ*4.Q2E*;
MNENBHJ*BHJ*BHJ*BHJ*BHJ9F"I5PQ+1FF[LW3=TYF6XHG+>9F6XJK6JJJJN9
MEN*[NVZJKF9S,MQ1-43BJO.<MXJ<S,55W,55543%$U6WBJN9BJJJJJJJJNYB
MMN<W>W8MM#?<W.5QPW-UO.6QLFT&Q+G1ONMY;PW'/Z5^PDOT_9['QLKTUIQ_
MT/#;?,Z^#W#F^OW^O&,=SK^[/<OWS]QG,DA\1$^^PGYHCE&&R0`G\4_)D(6'
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M]R*BHJ*BJJJJJJJJJJJJJJ^6P[?$\0\H9(3Z`"3A#J7A.YSG_1<YZXYI^K*Z
M#TG_!ZE13^J8KNV6E#Y+)?MR*G^I,=*]W]51_-E68S)_>=VN/CW>FM;W];S2
M5:J=J62NQ=4_'\0^!T'7I]?,-H:;;4I9-<5S,S,S-B(Z0-PP`6L at 95@$N"41
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MG<)S"U/"KT5K//;;`;#*LJ;*OJ=W-8H]1ZIUFJIQ3%5R3K.D5?*KH]X>3][Z
MMT<S7C,QPD<5*6TM6EJ6RTHP92R9,A?OHW\8^2R,*O4>8K?%2#.N$\U!U2\/
M*OKF,&,8+6*UC6K&H5^!/;E51Z<V'3W,Z_=<'MPM"T]_XSW$.WH03;24]V>F
M9D;7,;,<QLMF9F8YC9]TR24#O:67Q1R2D.T.Q21,DGXZV>7Q]20U\;N\\KSR
M`UUW>== :\N[SMT5=UY+R FFM;:QD]LVGMGQ*<I\4PZ?FRDY4#T7MYK*L5R>
M"QXX:8]GSFI$]E7JI?NKT7->UKO at I_0NY/?)??ZY\Y.WV6JLQ/SUZ+\\_\<0
M2[1L*I<Q^?<NXQE1O--M-L6%2X:U12L,19EM/[<228/2CR[(T>\[GF:U926I
M:E+$S'WC)MB6T\\Y?&K%4N,5%<&^-'?)A;5"_2GSK^3]+BE7B#%A64E3TS&#
MG'%:^?KF$S77<K!(9 at 3Q3OFRPYGCBN!K=M>%2,.PQ+)2MCECZI3?OJQ*'DF2
M^7JS,!]VKX7Q;Y>^U\=?W=O["_0 at C%_#_.$KL"=4AQNMM7'%F$A^O.A-)A)$
MLMBV+9;%LX2;'$BG9%3R#-O+"X8EJVT]_PMMMMWNV)XB)Z7UZ']6DQ&.J56S
M-AK6JDIFF94U_*3C_"''A3R>S=7]/M>V_0UA($W3V\)(KY.WOMMMM];SO5KR
M<J\_TAV/EJKV)>_PWXXY"*WVYN._6M?8U8V998(UW)BUQC6$3W>KEPS[-&_%
MUO78$/"I+HR4JTJ<:=^&8S&8S&87`#TD)ZS/7V3/3<EFQAADW+PR9P:4Y at X6
MRVA3&YZ@]<$3AZ=B^H\O94DD/1.4E9&$=)-HBU*;53M//QY<ZE(PB]1T8FYN
M+!MH<N9</#0\J'!0ARMYRYF9G-N\-R]PD"!G9]@628$LD]67-E,3+$RAE&5,
M3*FZP+H,BL&53$K&`,)I;:FAK5 at LX*29+19;:-2GA%!8+;,X&HW30U at 61JK&
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M(6E:9]]*#+;!RJEB1&C!N8M DMZR22""?A at .8!DHDB?7]/=!_CY3U5.(JD]5
M3B*JGJJ#U3N:JG$57V899@`!. at .0.WRX#7N/5[>S2BM5WU?)YZUF=,6L_-Z2
MHY;Q+1;+5JT<K(-[?6(TBR#J9ADU\JU"4U/1:!"U.?@SISJ:^MPTL3*"ZWI'
MGD1Q-Y'E]-MMMMMH```````````%[W<``!_P>?/->O0````````````!\OJO
M/ `````````%MMQ;;;7Q))S?P:S[_))(AWIV'SAD"6FG@!^W[*IJ_3VUPK^!
M1COV/X_ at _;]FSX-M4\,2RQI)UZ,N1=9JAB1*LJ7M;>V[?P-;>I2Q6:7U,1HP
MMDYY\TERA+\[Q<6 at Y76%B/;]K2:7E\F-H4>R#(AX?#048[*70E </AX!$/-]
MA1,1$?%B()3-N]Q#$+*V=@[LM]/ )@%%-6[K!7;>>'DP>/C(9D?'C-+=K6=>
M,?%7>. at G.$&4((613D(BC;J*E\Y,35,0J678/D>NWC>6\K4[>,?%7J&3VU*
M6%@2@*3&+)9&5A>'5-7PYPZ["Y.QINR39UFL:7XGU. ^Q\J]WWFO at GEKOF.Q
M/W?<P>8A9)RBD9DZTD\UCOJ:VVVBV_#YHHK\*555<VA$,1%W4K;KDFU*;;%;
M575K%:1J?3Y&=^-,_*MI>T.CJFT/O!V^?(E;`=&'VQX^J#_I<>'BJ0>JIXJD
M'JJ>JH/7+EOOG+EIMRY<NBXD]54YSQG at 1\"=M6W*'SZ';7H1Q/C)H]DQV8PP
M>XQ:9F7*NM7]'2K1QZ])M/!:[.:H['J^OC/#CU^8EZIS46+L5%VYN+%V*BH*
M>!:>[$5)B9<^;EO[9'E)O/!!3FG1VA6U.VO(UCE/'N\9\_*O'V595-(WD[WL
M4A]S5X;U_JC5>%GJ])7AOF$+\5##S'H5(Z9=4V<-4NF,6BL4M+2V+?-'T.]$
M]D=&=\VJ]AB<2ZUJ>WXYG/I14+;5LJST1J(SP at S&8L<SF.LIA;7A)]N3)D:%
M3"VQ:6M^T<Y>8TZXS&8S&+RAPF?=7?7AI6W_O\J5 at 88![J20-V 39'Y:_#M6
M_J9\RX;V`3-*=8=KAH;AJO.^4)YS/&]69 -3Y4[(4" )*"3LR0JZ1M65#!Y5
M: G<Y+("#46 '@N_72Y&/4KLZ-NM25V,D9 75V=CDDF[D1.GOUY[CC#;+YB'
M/.OGXYSH'9J06FG#+CS(7ANEOB7;YZ#@.KQ]69EHMMMNA#<TC=T1-,NKD[0Z
MG41Q24WY#V+T6>,SF;F^'=@;,.&FS)LX,V4MEH&FAN&%;RJX:>?IZN'JZDAV
MNAJ<>[V\F,YR?O.QQ3="RS0DZKAR(=7#0DF/.*#17(,)F%=YQL&X=:KVP*20
MP(3A">623R\>NK4K6VM3R\_<(=\;Y at G@R9>)"QP[N[4X[NFQNFA*X0:39 F4
MSW$^8U:L8A-G'%6XT+B=0$.:73OMB,"<WD/HTX at 1&<WG&16+NTDX**H9X9T3
M(Z<2XW!Z<X6IQ%=(!B(-'H[:2N4!L1MG>YDDEE:&]J=5&!OA6-0A!&V!D2(V
M#C+3)>1O=.)P%G>%F<11V@&'@T=W;25R at -B-E;HDM5(;4IJHT-L*QF$((U at 9
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M+>HQYS*MB%_D at IVS:=A?\GC-5\+G6!WLD]JQ$-D_.\5_N9ZDO$5%UEUG,W$K
M[%'8,I&_;-3 at HIE5!:QR0;I)K>DC0ULM73SV2---5\S.C,VHJA:6Q>2$P,Y,
M4E5Y&Y at TNUYO!@I,.];6C:F][[[^2WO5;3G.SE-<RO G0-;)O-)UI?!/<2MI
M#8YVBK#*NLY315V=*O/;>>$T4I['./?E6&,3F3LZIR+ID]9,56:TY)L>"Y1[
MZOJKE-E+UKQP98C.LU5;/V/>])OQ5$>7BS,QK77=T8((@%G:_R[>6\ ``^?;
M;K0`-->M5N\MWFE52I9-0M32:%P?9]6H[LLRS);+9@\$3017FDW#<CZ.#/61
M<5>+N3KN3KKG<[DZ[3^Y`%:]]3Q\;E-TUW1V)^56WM.55RO7W=GGF%>WV;]V
MR&EG5R3CS$.%:<KQYB'"SEY=O*<MH<TYG,0X5IRLE+#!@DC"D*3\' DOEKP8
MQ;;;H[XD^>6^F*F#TG"2:M[T5O(;8.GK6K5JU at -".V0B[K;;;:CXL>SC;;WY
M(!_1[(CE231Y!PR)&;!&0W[ZJVU=\1JV=:)L1L2[?45$+P=(&(R&(!!!9BA;
M1()%B;I*"[DBF*J02*%1*@F35"9$&!0BDF+ at E]6S;7;&EQ#=;5OCHW-S8>N.
M4;I)\MC,BFWSKKXZ][7:O?V]`$"2RO+#NC:<04X5D#QG$U+>>?L/3&D]O1W\
MU56K5I).\D]_I2$I-(0^7'F/9 M))&+)B.>G%F#PH9.Y^G9>YMS>I"3/&'K]
M?#R2..8F9;UU:4O D)V at 9%?U/-U5.$POC..>QAN<EI>S)..LER3DFE):3V>+
MM,%AD6,;29%$R)D$A,RVUY6M9F8QE/LWU5S19-Y63DL3X15O6NJO0 UH`-?#
M5OCKJ\ +``K2TTM;]>NM=:6V5DR9-R:72D[Y\0NR=?*D^;X,ON7(O+;?H\L]
M=QLN445%%XC]I\&"'*=.NK5MLM3 [9.?/$F(HZ:)&1EL06(L[$\!Y6?A" ,0
M#TB*A!A!LF&*]WPR^TL9\RZMHRL3VE[_H^SVNJL<=S,5S,S)]66VE+R'?;"N
M-F%K%+2U]R/*-8U]_S$9G(\CCCU]-\/PE;!-&1(1"%(%A?4?K#(!SEN"I)D-
M49;QB;]]R57TJPJK%4JU54\M$^K<.[C(1'<Z4M+7LBKE^[:WJJ]:EO+TO$YP
MDYPYS,UK3.UOU+P>%=Y3'V4O?/,/B_><)>A?L]I at HBB*(HGJ(0(,"0]OBP#S
MN/D[IMG+,QAA+BVL3M(;3NB+?7)Z]/ .#JED.WF^FNTGRJY>X&$/J=$Y?.%]
M`&_I>WQ;F9EUW=RZVNZYF9EUTAZ_?/"J66++%ME*L60X,PD#AJ[V/+RS.04<
M,(3=<P];DWRY\.D4``\9Z=2L&9F#,H9F5 at S4O01"R%$(3E&(():)921*4&4M
MMMOCT^!NVIFAN\J,(RK-13)5;N6-4.J;&PW37 T7O:7+[?O-OW;;]7]#W]XO
MVZZS--S"8.!C-+;V7JR>3P,/"(@80BV8B%=,!70<^6PN5#9S9S1X`8LP!9FM
MFLL6IAVOZHF@,U-,$A,5<-*3F9M(DQ<I!!Y9[*J)A4G29/+.7DR:ZYJSG4,-
M>E,Y.L>MDZA"`\H62D9IPAT95HWGJI#\Q1J8N]+TQ+LG)NZ57&54C*LJGOY$
MWG*=KQF1XL[\FZF<Z&*JFY.U)K!Q[Y)CO-.2A\(=0[=H3.4D`\_M>[[-W=W,
MS,<S',V)'G\HU1B.3?2TM+2TM<O1NQC&,8Q5K]$.T.'5$AYP^J&SD.#3Q;:U
MMC3C%8KC).YUG=6Z-6U=QXT>$DJ)Z* \B>1],^0!I\O?\5555?(GE;;;;> >
MP<JEJ9,'3#P8[<;^+QV8EM5H<E)UM+,HRKHZO)F1*HQ1T))T#[N3$:<./HSV
MQV^>K5JU;OG9T1;I'>(G2-2QE&J.<:'='F'+O+2>93>[T2&[A"@1YG=6&_F=
MGP`<\X2E22L4]R,)-="2!D+;<,,KD?EN&79"4W>6G@'FN(X73NK@: [IW(P[
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M2Y<4]$08,NBXF8$1"<N$I4P\07$S$;;L"VX8;@),`2P8F^GX]$'^W9/,H/,I
MYE!YE3,AYEW,R@\S8_(X)((/X,/(>8_,PZN^,]\FQT]WE]QT0Q&6!A\NLFSV
M(F.$)[G=MM;9*3VO6]>O%5S<)1Z3I?WL_1\94^J9%"Y)3,)D,JL9(>A+1J!_
MJ+- at QV^'\-=4Y^_P'Y/"].4OQS:P&(T:MK\J_=5]5-K7****************
M-_9G."Y1HQ1111,PS#,,PS&4AZ2N"H5UK9V=:[$O)XU7;,9998RS/LS7.31J
MT5J-MC:MG&562J?AZ5C%,K,M0;,@&,IA8?VVFF15DD9EF,IF88BQ/T<D\%2K
M`J15+;2(EI"?%)CJ3PW1[/J]Q:)!(-4?H1 $N"!.#MT51$M>$''S\ZJJJJE5
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MB&2%D64)Z8Q+4G8[EV=KPGM2_+MWOT10?*>,[3NQQ+Q\1EMXYF.,`) )`+](
M8#C]+DD$GWBL9<,]=I\FB(>)8"Z]=L\\'-YCN[-,DTG*>D*-/0/E9+9 I"=Z
MQK&E*6QC5L&-6H+&-N[ D DUH"2W;6W[NOG9SJ/&O:9V#%75N'PSX:U*PU]]
MFBR+8324VR$ZV]*#<[1AZX1^3*J^B844[C2?45W;MJO?ZJ=UDI\CBE7BVQS4
MHV5Y>[[6T\4Y9DSGFLS.?OG'AZNXU&CWE57%]*?%J=()`"R2$ZA/9C:"H6Q4
M+86JR6M:F9;*$<J[)];XO;.[I*_!ZW*J]9D[2KR[2N+S>K'@.573NJ,40NXK
M$=+.JIZT61XZ;J8!<4A@@L*>U at 4DDLE)+ [=`J"B"Q;&C6FU44M:K)^[?ZO:
M\F->2+WK`6(D"6,>%T95WQO1/&^")C$MG9CNS,YC, I96#*""04S#U]_P0^O
MOCRN^DJ/MD07UK!\'_1&[N9F9B",5)O&&P]+$JE6+3X49L9G"C.$,3)(SBU+
MHTD<R'/ZN9N\8EY.9T]W1DPCHD747,U>+K;G08!<I.D"'0<.R8$!V+!R!EC8
M)168(DL6?'">T[H;($(2>T8,J)!!\8]?JP0*]EK9#'N:8R5HK8J-H*> 2-MF
M39A93L-D`C%C: [FR2SS93"\. \U>($P)>Z0JD&(>6Q>)8IHJ)*88IPYFKQP
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M#-ME:,1OVTO2:(QPW."FT:U,K%9-\;_ at CJB<D<3DNDU5]W>W73[XQ4=F*U&>
MG-I2J;L4SNK:;)+:STOUZM>/O:);!N1KA;+1685AA#!A6M+\W+,WVV[F9NDU
MRXTRS7=TCEU*X1S&:6-U&I^?X>I'9.DXIGCHN<'5,);N=MJELP607FED-:P3
M`8D1344:+R=$7.;>O?<Z+LCU4'N)WWGGY9X0W>6%;<9GM>E6Y/A<^0HKF8),
M,*K^;HKP&/TK5OQ,%UJP"0SX>.E5;6+H;3H*2!.H!"A"U92M3*D;,#)FI at 5I
M,&&&L68RU-:F5*;2I at V38QJ:,I;28K,J;8,6'>MMGP3J=6L=>,.D2=(L at J<'
M&N\,\WIVSC&N6C30F($"()J9B)#NZ#AW)@>K``M0`SD#(U^F_6VW40O:Q3X5
ME]>V9C&O%BUE!:I#-I,JB.,!&U(;;YF629Y5FV6U5TM5%MNX) D$B%VM.KS7
MEO->:Z^K2W62I#&G?TZ,>2)VQV-HR-=D[LI)T3LEM33-/Z3,-=9-::K^UU]O
MPNOK6ZMEJ=?;\)JX6<R>SY3N]<[9FNU-I;9X905B'!PKOBL5JCR\(-]&%J^!
M['=U&\O'PC::14M2G%UB[O9&O'I6NFF9=I.SZ^-MNWOVJJ.R<E'966I2KHA$
MWN,DS;$AQF5C(&L_$O)W5;APAODG&QOU4UK at T:\KA6,LFBI9+I6Q;6#6@&-M
M(?L=MAV))"0GNSY?#WZ'****+VKKI^RM==5E(BJI_LSA#(CUW-H%LA9"D9#F
MJ_C:B:C%3)55DJ,K$961E83%62LK*AN%)E4P]&4+!06)6(QK#,ODZO;25MU]
MBB)U'<GI>=_1EW.<Z6+$2V-_/DF?T5^3_&X1-R-V,VTR,X1&]$]N-+5D6_+Q
M) "3"8?L0](_N-&MC3VPOXNV$SS at Q:+"/;SR9G:_"EKL^2]L[MWN#:ORCM-:
M[*,6%I:6EI:6M=I$@;JO];VM)O/?7[Z;E:KNP8R)#&7U3<-TX;I<..XNG\U]
MU;:JW32XJ/6^!'2=5Q)._%MS<6Y1GI\"3T(YLIVRKL3(K,#H:JY1;$4^^\HR
MC at QW#RWM*_@]_CI-(BW5S=\-.,<4AM_%;UFUS),K[O6))YY;;)6I6*H_9[(H
M-)Y145_HNY748412^%RBOC!<YCSX[\[7RUM^%K?2.<>B(\8^_FVVVWB>Q.9[
M%G4J52K)-)I-)I-)I-)I-)E5[=DM6T5'I62:&@[ST85,X at TAU"3WN0^H.4)Y
M^H-P,R-Q,R-W6;=4,P-])#HGW/'H>)[I.<&3`G,]&D,923#VUZQ.4K)#I239
M-'<ZSMM94^-_G^6MRLA;M2E%OQ)=^5)/:Z[:MJM;UO9BBBBBBBBBBBBB[7V.
M:=WGG>.[;K;=>***********+JSNL?;:#KCHB:6VI&C;6/2E[J9'@8PBJ*OB
MB;CMX=U23[F#+,2XQ)I<Y^G3=I9J(<8$RF6Z"(4F+"6R26R_1E&L3,*-YDO*
MMF at F93VAD:#*7)89 at T+*3 S),!9+0@=R2%A#O82;J;]6]^;3A,:VC;92RTM"
M[<N7>7FR<Y:MACF7>7FR;RVJ[6O.<F\BT+C%MQR\Y>:3>6WN;76U>*U5*RU<
M.B2IDC(H;&2C$OKQ)M3?9[,S&,66JMA45&DDZ@]/LU^3,K&<Y9RSG.%5G %!
MM004DDDEE4DDDG8 at F@]^]4)-!=*6,JYSS3P;X+BGK91!C DYHVDF-DX<#Q5:
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MQ)QXXL255JU5EL6H-R(SW:I*O at E=`PTDW^K,TM:TJE>F5Y,_$92![FGVO"MY
MA);LL923SUWGH $!C `8H " P 4```````&"( $H2 `$@ @`"" ````(``@!
M# `````)```&H `````"2 3 !! $````D ```````!&K````````0 ``````
M````& $(A( `" $@+ ```$@``````A ```````````````!0````$$! "0%V
MJ77\-K_0TU\_FD!\_A>K_!^GU;6];-K?7:U7]HM?B ``MM$5H-;:B-MKFUMP
MU5RVK7,8QC&,8HC&HQC&QC&,6,8QBMA QMLFVYJK45K5PHBUH+8C!M:JY7(M
MK<JV\JV^=;WQI?-"#\^VBX)$@>"%A+"1H$--BKQRX4-&R+&L<D62HZD'`.6+
M2+G&Y1111111111111111?NU^F][^4P(H='2EJ=V1&\R8Q,GR[[E71=S,Q%R
MPRW"TS,MPM,S#"TS#+<+3/RF8U5]+-N6,L*JL87#6$J38CYD=1%W/QGPG>FV
M#QC R96308G55TGC%![^`0OC&^+4[/D]GKBZPXFV<D>$92N]/!'.NQY\VFC,
MQ-:$M7KG?*@NR*#<H<-YORZ;S?UX>IBFPMVT+OR%NEO9K T8,;%%1C8L98/7
M7FO-<1!A"(,?'7]>U]V*T7,-3>;U5/3 &8+57*9F,Q;;+;(C<26,`9A.<E9B
MQ at W9E;1W+O4GHG0O->:>QZ89C\;ZYX7?/==MRK7X\A\"H5BZT<3#*-B/KN5F
M>4CH>I2HP>]'EHS6M8QC6M-:UK6M8C]W?RKTRIZ+`H\DQ*OV)JH_(J[1=5=O
M<[LJ,P4LV(4[,+FXS,'J9YTAB/@H8/=5RF391M.L+=-3F'@EOF3*3Q1C<YZ]
MI<IBX34]OP(75=\P_MAJ?/*#E/)=P??5\OJJ_@]8=%[SS#U)YNY)&48C`Z1C
MAS.E-_#"1;,VWTYN<N4S,<(J"HR<W/OF\TZZ]^8</MR3C)CZO!UQ[YE<N")A
MA1,*6JMJ#7$S$PLPQF4,4M:&50)<\?OBYL#>_?(!H9H]1CAEBA3#$8B \K#H
MAT""S+&(<(2MS<$Z-9DWG,YSF"<-I*!>D+5O6&+C"&8*0DE PDN$)0),)(X&
M9_*UK>=O^;PW#B$YUJJK[)>L[I^"^6UN):V1W82YQBT>^3#-+2TM+6?=-3;Q
M.-E5;<;GR[[;BXM^E-R)\J+$G-U3FJG8OGV\,8UA[4]-^=0'[*HRK%5:M6Q3
M= '92/C)8YQ9)Z"/A-AM[[&IW>D]7<]-W%XSP3VSU]X:3W5*(5K5JU:N)-""
MN:>DD\$B!WN['SSPST=:2=%EGL^;G*>YZG]M7E>?A%!W\.78>:'=62H].ND>
M262W?7Q/EHG-QGLPIWN%<$[IYJ&$>$=(RDI>*YW-9Q7RS/[/ZS>\$&5"\:$P
MCVIRC]OC.LMUQBUIV2S)<2EE+*66TWQTKP>7TS,S,S/DN@?&<JYI071]4^$=
M\_!N<XX$?Z&J?#V/)-SV^SLGNZN08PN><S,L'&<#73,V/G8*BO^:R!T<J5H=
MXGL%2F!<P]JFTK::GC<0FDBDZ=4G7)-BQB MMMMMJ/""Q4D2QX+&8L?=B>4=
M/==TN+A<7%Q><@``'MKM]>V^'T[O//.\>7EV)Z-:]6.D-_ at X(#56^N6+*,&8
MRU92M6RUO5VXU3%M8H\R+1 at RI90,2Q1O1<936Y)-$))82%*$(FXYVS,F&3)A
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M`X]:UY;+NN+;NC"Q)#PBQXHW2.A!.N3L_';;;;VFQ(2/#L%7NB_793TD.7B9
M,LS,9AF47+QL^WN,N44444447G5]_O5*?JA/MGEQZ3LB.]/B^J'N<',["OO^
M[\)OG5O5YK\OD$C7U;?/75_*`+;;;;=DW0G"-4?)'%'>X5HCS3F'9&Q,.J?&
M:DK:=LU#1 at 8AVXK-]04P6J=&?&?Q.8<IE1R#A(\SYSLJ.)Y$U?/%@91='0QT
M8P,\9[X/VXV?L>3[_BJE+L6S`X]3KC13PKYSAL3E.^K#)P\$R1ZOCK08"%SG
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MU<.3$J9B(B($"HB 'W0"XQ(U(G:+)*(^58$T4 $G=.V&<JN"`31 @*!$RAD=
M\-E2VCU^&^^O\?[OO[AY(\7-4OMU5YYY!X>9;8\=97HO7J8EV<)<L(% G3P(
M^ZGQ.5K?+MUDX6<EG#APRSE:ZKAF9:KD7AF[N%XF8DPISGPYPVE6]GJL)<S)
M-F:S'IK6:T:"JC,E4?'35)2-Y3*DS-!WQ41\>V&,!S:JM6L=>FYPUXNSRV\_
M5QV[.S7H``S6'U.5F>%IX(V/%D9D0Y&DG$+1S%@V8&IT^M(>9:JJH$1$1N#=
M'IP-=!TVSK:>F\@[;FUA:0M:=K/M:)?)]:JL86M6T;,082B9RI(6I.U>.[NY
M=N_]%=GCG&DY*N66G>8=]#%*3X&DY9P-(\[<839EEL.!21E.$Y3HR=&2;<.
M!22'`4EPE0J3:9)A+"QG-AS-UQEL8LII*"R$R%8DN3C3D&&4L+%3*)M2;)0L
MLB4X3+$$`P2]!I-L-FMGC7:N(^6NHEYY1[FISI#I2'%(>A5N)<EOV%Z5 at .R4
M[:L+B.AX'N88T=J][V-DY3S34R9,K[]<`. #@D;9P!W!(!(VS332L1)0"3N
M+-=K at 2--+2I0^UV..M*M/:GU/J,%7RE-*M#ZP]TF9)#M!?%HU+=DFDA('M,.
M6%MA@<[F;;!9F3*IC*"T<K;R\[E(.8\$_3Q,%BLA5'8Q<-RF*6Y6RVUJ44+4
M##"23](G<Y#QY_2 D$ ;E>@6B" 4BDB2000F]W7LS,S,S!F95[S[?P^$`G=\
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MVHWO5;-M;>?<``!]NOOVS?3?%?%/"AAF6%LW-;;;;#:02-#]V$7 >;L4+11&
M^2LQ#,"9DB6A-5X.V;!Y]M>&X91SWSNV7=FG>NIJ32(^4NT9PB56Y$J<V,N_
MKSK"Z;N89B+DPS-";(0IZ3P3ZX>P$#UA1LR'JDD"0X=R')R3V=_A>^.7-W-N
MUKNVF;=YR6Q at QDEI)/A\G[M<<S-S+NY<9ZNSQ,8MMMT/Y/I1,Y*8D23S,G%W
MP9[%)&-^DWZ_2>;U5<CE.SH]>68[5Q&.Y:+H23K1ZS.RU:M78V2(G1XD>?4A
MEPB/+U6VJNB#<C at _$\Z/![^/:=Y%)?O^#Y1$CB9LDOLA*VS*VD);"V!"5DD_
M0Y\U5:M7[?VZ`_7K]?>6\_&_??+]7TEOX>'G=/M_+[Q&&-J<89C*0PS_O_W/
M^?Y2E6\HRK at 60;@@TA!G2%DX41,F9$Y"Q12I4%3#`[#&$^&?JY<-N%X:7?Y5
MOYI&N$:A[-U>MA at DY:MSI!R"MD39 at Z!BW+63$)8C#/5BKB1B,A:E:6CZ^\,D
M\= >?HL4[=O&.9SEIQMKI]7/&,<,[<X at 1T2SC$;^EKG9:)!AEE,SXB7)@%%(
M(D\%38N[&\4`GEUF;N7+"RX>;3P2JB)D;11&2T480S at +"G!:#)IQ(-*!38*%
M4*J(@1%XA8 at T)F1F, 42228!A)S@%[2>L:S6)3#1T9$8TG at E',0[E'069E4)
MB4,18$4B"3(,I.<`O:3WC6:Q*89,![RG at Y3G,S.<BB2"2Z2**.,!#.%)P1!8
M(2C"S3R9LR5-O5FI5 at HQHJ9 "+2D,IX>P\2,18%$@DP#"3K+JTGK&HS6*3#1
MT9HF<Z422CJ(3HI(`L"GK-PRF%D&VRVT`Q@`!7+WDV22C5):_NI<^[G9B\.Y
MOR[UQ;&$PG^IVG'>..*,HSM'1-F3;:N!L3>^%8\0W-$<_KG5+G6]44W3&QB/
M7 at F^^-8MLMMC>:>4$]<1;"?=(WZU;V_#TDD==WYWNHHHO-?;;KQ1111J+%%%
M%%%$S#,=Z<Z'JF'"951_8M)ZK,0T3&FS=2TM+2UNWJD36+N.R+'1A'5%1[NA
M)JC at XTM+9NO".6L8C#?JV6K\/57\M]E]E%\!B 'Z)U&P>-R 'DZB@\;D`/)U
M%>+D`#R<%0>-R%MMN5P6FUC,:(V0I'*-(VBQUNUOCL4D;POMZ$*I<GQ5.E+5
MR<IJ*#7PJ\!NF\%/'U3.T[L8C1M%%>OG`+-?A77T%K[+Y3M^Z[*OVSM-E=L>
M]FV995[)3"1R7*1Y at Q4:R>+H[(Q)KU,]UMMMM1WQ2=4\N*K[$T790=)Q/;A)
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M1KW92(YI2:QDAC\[EU6]=871&SX5UHGE(DYQ,DU)<L9*;;[:6M9C&:VKM2 at L
ME#M=E(8M.'),5Q-34\Z\GWMTYIQ/7M&IVZ+V49,7B=V&8XNXG$Y0N\3OV)TI
M;F)#%=D[MUXSE-4GJ37NJ%LE5)9QB%1HZ1(<_"VU5R>LYTJM]<)U^N,(3WGS
M& 2$-)8?,@^J="=:KU7 at HA? ]*N2*E_/XE;*1P/[)5I+;9(]J$X at LD2:<NZ-
M&C5JN$G[=+0 at 2$^Z!+T>P))"'DH>%+SEJLO-BQK56&-/1[,;US3J^DAYI?!>
MR'X.1B=>JROZ?N^Y4VMA"T/E;:J7LUJHXY3+5\@)^@$OE$DV-1WE3"VS30FO
M?$\++;>FYG-6(MMM,]<9AE:LA5D8CEV\X))76=B[EYFRZ&DP8+"L)9E1[ID7
M8'T-R=:O[=J-J7.QV4:6K!LTVVJ^S^'T) S)``+;56JMJEF$/".X8K6/9$C)
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M#UZD'KD?T*<4X1[G1[Z^EMY7[-N)`"MLK9K;6OL]6E/0_+VZ<)O3;&S)Z6#+
M%*];S>X'?RFW at O2/D>';M7T04U4R^UV$Y!PAZD'A<^%+9Z5O*<IS##<T;.5I
MG#AKAIEG*V9PYNELY6\X8X-FUIR=SJ9L^$\"*ZU2^_&9F3KE*M48(RPR9"8R
ME64R5=9S3G(^5&)VIH-*+LFS95'YL4JLRA<-O-J]R=V&8]LBE97GQ[.6/X at F
MZ'_)(_.Q;)')_2LZ?FN/G4PSI^B?K\Q,PFY5QA?Z?^'JM__B[DBG"A(1WU;%
end
