configure problems
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Jan 4 23:22:20 UTC 2005
Greg.. I do not see these on the main RTEMS development machine
but did see them over the weekend when I checked on a fresh
tree on a Fedora Core 2 laptop.
What OS are you running?
I was planning on doing a fresh checkout on the main RTEMS
machine and seeing if it was repeatable there.  Otherwise,
I will have to debug it on the SLOW laptop.
--joel
gregory.menke at gsfc.nasa.gov wrote:
> I'm working up at the cvs head using gcc-3.3.3.  I'm running bootstrap
> with
> autoconf-2.59 with autoconf-2.59-quoting-20040817-1.diff
> automake-1.92
> and it seems to complete OK.  My standard ./configure completes OK
> too.  However, when I make, a number of MIPS targets fail to build
> down in libcpu, among other places.
> A representative location is, when linking isr-entries.o, the Makefile
> is looking for interrupts/isr-entries.o, but the file is actually
> located in the parent directory.  The failure generally occurs when a
> series of makes in recursive directories generate their .o's in the
> parent directory, but the Makefile is expecting them to be in the
> subdirectories and so fails when doing ld -r to aggregate a bunch of
> .o's.
> The other possibly related problem is the configure pass occasionally
> leaves $() macros in the makefile (libcpu as well), causing syntax
> errors.
> Simply editing the Makefile to look in the right spot or to comment
> out the spurious macro allows the make to proceed to completion.
> Built images run fine.
> However, the mcp750 and mtx603e both build fine.
> THis behavior has persisted for a month or so now, despite tree-wide
> cvs updates and re-bootstrapping.  I imagine its not something broken
> in the RTEMS source, the likelihood being something is broken locally.
> Thanks for any hints,
> Gregm
