RTEMS 4.6.2 build problem using cygwin, "multiple target patterns"
Ralf Corsepius ralf.corsepius at rtems.org
Wed Jan 5 14:05:20 UTC 2005
On Tue, 2005-01-04 at 12:13 -0500, Chris Welch wrote:
> The configuration (not significantly different from what was used with
> the 4.5.0 code base):
4.5's and 4.6's (and 4.7's) configuration are substantially different.
> ../rtems-4.6.2/configure –host=-i686-cygwin –target=m68k-rtems –
> program-prefix=m68k=rtems –disable-networking –disable-posix –disable-
> itron –enable-cxx –disable-tcpip –prefix=/cygdrive/c/dev/rtems
Where did you pick this line up? It is full of errors.
../rtems-4.6.2/configure --target=m68k-rtems --disable-networking \
--disable-itron --enable-cxx --disable-networking --prefix=<whatever>
Probably would have been what you want.
Ralf
