Help: Steps for creating an rtems device driver...
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Jan 6 23:29:18 UTC 2005
Alex wrote:
> Hi,
> Does anyone already created a rtems device driver?
> I need to create a simple device driver to listen printer port, but I am lost in the steps i need to do...
> Does someone know any doc with the steps to create a rtems device driver?
> I already try to use the polled single port sample but i am lost, in registering, fire the driver, etc...
The simple single polled driver does all that for you BUT it registers
itself as /dev/console.
Copy the shared console_polled code to lpt_polled and change console to
lpt everywhere.  Then you should be closer.
> Thanks
> Nuno Costa
> ________________________________________________________________________________
> Veja, em exclusivo no IOL, os vídeos da Quinta das Celebridades!
> http://www.iol.pt/correio/rodape.php?dst=0411152
