Abatron BDI2000 / Powerpc-rtems.
Mark Dean M.Dean at sstl.co.uk
Fri Jan 7 11:44:19 UTC 2005
forgot to send to the list too...
-----Original Message-----
Sent: 07 January 2005 08:55
To: 'Steve Holle'
Subject: RE: Abatron BDI2000 / Powerpc-rtems.
Yeah, I know. But the watchdog is disabled. I can remove/add code so that the time to the idle section of the application changes and every time it crashes as soon as the application finishes processing and goes idle...
Sent: 06 January 2005 17:56
To: Mark Dean; Rtems-Users (E-mail)
Subject: Re: Abatron BDI2000 / Powerpc-rtems.
Sounds like a watchdog.
At 09:00 AM 1/6/2005, Mark Dean wrote:
>Anyone seen a problem with the Abatron BDI2000 where when there are no
>user tasks running it halts the processor then when I try to 'continue'
>the board resets? Its very odd, without the BDI connected everything is
>totally fine. I'm also able to set breakpoints, examine source code,
>registers, memory etc. etc. in the normal way. It just falls over when my
>application tasks are all idle. This makes me think its having a problem
>way down at the RTEMS level somewhere.
>    Cheers,
>       Mark.
Steve Holle
Link Communications, Inc.
1035 Cerise Rd.
Billings, MT  59101
sholle at link-comm.com
