Network on POSIX (linux) target?
Keith Robertson kjrobert at alumni.uwaterloo.ca
Tue Jan 11 12:11:52 UTC 2005
Hi Karel,
I looked into this a fair bit and decided that, for me at least, the
best way to go was with the i386 port and QEMU or Bochs.  You can get
all the advantages of windows/linux development/test environment plus a
full featured rtems port.
You may be interested to read these links/posts too:
http://www.rtems.com/ml/rtems-users/2004/november/msg00307.html
http://www.rtems.org/phpwiki/index.php/Bochs
Keith
BTW: if you go this route I strongly recommend using grub + mkisofs to
boot your image.  It's a lot easier than faffing around with harddisk
parameters in bochs.
Karel Gardas wrote:
> Hello,
> I've found this thread from 2000:
> http://www.rtems.com/ml/rtems-users/2000/october/msg00189.html
> and I'm curious if there are any news about networking setup for POSIX
> RTEMS target. From looking into sources, I would guess that the networking
> is unimplemented for POSIX, but I'm not sure if it is not hidden (shared
> from) somewhere.
> Thanks,
> Karel
> Karel Gardas                  kgardas at objectsecurity.com
> ObjectSecurity Ltd.           http://www.objectsecurity.com
