Network on POSIX (linux) target?
Karel Gardas kgardas at objectsecurity.com
Tue Jan 11 12:26:24 UTC 2005
Hi Keith,
On Tue, 11 Jan 2005, Keith Robertson wrote:
> Hi Karel,
> I looked into this a fair bit and decided that, for me at least, the
> best way to go was with the i386 port and QEMU or Bochs.  You can get
> all the advantages of windows/linux development/test environment plus a
> full featured rtems port.
> You may be interested to read these links/posts too:
> http://www.rtems.com/ml/rtems-users/2004/november/msg00307.html
> http://www.rtems.org/phpwiki/index.php/Bochs
Thanks to google, I've already also found these links.
> BTW: if you go this route I strongly recommend using grub + mkisofs to
> boot your image.  It's a lot easier than faffing around with harddisk
> parameters in bochs.
I'm personally more interesting in trying qemu (because of positive
experience with it), so I will follow more qemu related information
provided by Lars Munch in the post above.
Thanks,
Karel
ObjectSecurity Ltd.           http://www.objectsecurity.com
