[rtems-4-6-branch] i386/pc386 BSP compilation failure
Karel Gardas
kgardas at objectsecurity.com
Tue Jan 11 12:39:44 UTC 2005
Hello,
I'm trying to compile yesterday sources from rtems-4-6-branch for pc386
BSP, but build fails with:
i386-rtems-gcc --pipe -B../../../../../../../lib/
-B../../../../../../../pc386/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H
-isystem ../../../../../../../pc386/lib/include -O4 -g -Wall -ansi
-fasm -o o-optimize/tod.o -c
../../../../../../../../../rtems/c/src/lib/libbsp/i386/pc386/clock/../../../shared/tod.c
../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c:13:17:
tod.h: No such file or directory
../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c: In
function `rtc_initialize':
../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c:102:
warning: implicit declaration of function `setRealTimeToRTEMS'
../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c: At top
level:
../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c:119:
warning: type mismatch with previous implicit declaration
warning: previous implicit declaration of `setRealTimeToRTEMS'
warning: `setRealTimeToRTEMS' was previously implicitly declared to return
`int'
make[6]: *** [o-optimize/tod.o] Error 1
make[6]: Leaving directory
`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp/i386/pc386/clock'
make[5]: *** [all-recursive] Error 1
make[5]: Leaving directory
`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp/i386/pc386'
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory
`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp/i386'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory
`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory
`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c'
make: *** [all-recursive] Error 1
gcc is configured as:
thinkpad:/mnt/karel/downloads/RTEMS/build/tools/obj-rtems$ i386-rtems-gcc
-v
Reading specs from
/mnt/karel/rtems-x86-toolchain/lib/gcc-lib/i386-rtems/3.2.3/specs
Configured with: ../gcc-3.2.3/configure
--prefix=/mnt/karel/rtems-x86-toolchain --target=i386-rtems --with-gnu-as
--with-gnu-ld --with-newlib --verbose --enable-threads
--enable-languages=c,c++
Thread model: rtems
gcc version 3.2.3
Should I report this error to your bugtracking system?
Thanks,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
