Solved: RE: How should use 'powerpc-rtems-gdb' to debug an RTEMS application under simualtion?
Mills, John M. Mills.J at ems-t.com
Wed Jan 12 20:24:13 UTC 2005
All -
I found an example [albeit a pathological one] in ~examples-4.6.2/psim_frsp
where the README tells all about it.
Sorry for the wasted traffic.
 - Mills
-----Original Message-----
Sent: Wednesday, January 12, 2005 2:16 PM
To: RTEMS Users (E-mail)
Subject: How should use 'powerpc-rtems-gdb' to debug an RTEMS
All -
I want to step through a compiled RTEMS example with my 'powerpc-rtems-gdb'
running on a simulated target. My examples build and run from the console
using the 'psim' script.
To debug: I invoke 'powerpc-rtems-gdb', get the (gdb) prompt, enter 'target
sim', get a confirmation, enter 'file <filename>', get confirmation that the
symbols were read, then enter 'run'.
I get:
 'Starting program: <filename>'
 'Don't know how to run. Try "help target"'
If I enter
(gdb) sim test
it looks closer to success in that it tries to invoke 'psim', but still
doesn't run.
I expect I should do something analogous to the simulator setup in the
'psim' script, but don't know what's needed. (I would then save the setup in
a file to load into 'gdb' before a run.)
Environment:
 Cygwin, RTEMS-4.6.2, gdb-6.0 w/RTEMS patches.
Could someone please enlighten me?
TIA
 - Mills
John M. Mills
Staff Engineer
EMS Technologies
660 Engineering Drive
Norcross, GA 30092
770.263.9200 ext4882
