rtems object name
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Wed Jan 12 21:10:23 UTC 2005
Philip,
AFAIK multiple RTEMS objects can have the same name. The only
drawback is, that you can no longer identify an object by its
unique name :-)
wkr,
Thomas.
> i'm currently porting SDL (www.libsdl.org) which include a framework for
> creating SDL tasks, which look like this
> int SDL_SYS_CreateThread(SDL_Thread *thread, void *args)
> 	rtems_status_code   status;
> 	/*create the task*/
> 	status = rtems_task_create(rtems_build_name( 'S', 'D', 'L', 'T' ),
> 					1,
> 					RTEMS_MINIMUM_STACK_SIZE * 4,
> 					RTEMS_DEFAULT_MODES,
> 					RTEMS_NO_FLOATING_POINT | RTEMS_LOCAL,
> 					&thread->handle
> 	if ( status ) {
> 		SDL_SetError("Couldn't initialize thread");
> 		return(-1);
> 	/*start the task*/
> 	status = rtems_task_start ( thread->handle, RunThread,(rtems_task_argument) args);
> 	if ( status != 0 ) {
> 		SDL_SetError("Not enough resources to create thread");
> 		return(-1);
> 	return(0);
> ofcourse i dont know how many SDL_Thread will be created by the
> application using SDL...
> so, my question is,can differents object share a common name?
> Philippe
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
