stringify macro issue [was: Re: GCC 3.4.x + RTEMS 4.6.2 release.]
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Jan 13 22:50:12 UTC 2005
Karel Gardas wrote:
> Hello,
> I've found the reason why I had these strange issues with gcc3.2.3 and
> rtems 4.6.2. I've found them since I've also started to have them with
> rtems trunk and gcc3.4.3. The reason is that we write code like:
> class Foo
>     std::string stringify () const;
> while RTEMS seems to define stringify macro:
>      145
>      146 #define stringify( _x ) # _x
>      147
That means RTEMS violates the application namespace.  That
should be rtems_stringify.
But I don't see it used in RTEMS so it could be considered obsolete
and purged at this point.
> in file <target>/<bsp>/lib/include/rtems/system.h
> which causes corruption of our definition to:
>     std::string "" () const;
> which is really uncompilable. :-)
> Cheers,
> Karel
> On Thu, 13 Jan 2005, Karel Gardas wrote:
>>Hello,
>>since I have kind of strange issues with gcc3.2.3 as adviced to be used
>>with 4.6.2 release in its documentation, I would like to ask if anybody
>>here does have some experience with gcc 3.4.x with the latest RTEMS
>>release. The patch gcc-3.4.0-rtems-20040510.diff on ftp.rtems.com looks
>>really small. Does it means that every rtems related change against older
>>gcc versions are already merged into the 3.4.x branch?
>>Thanks,
>>Karel
>>Karel Gardas                  kgardas at objectsecurity.com
>>ObjectSecurity Ltd.           http://www.objectsecurity.com
