stringify macro issue [was: Re: GCC 3.4.x + RTEMS 4.6.2 release.]
Ralf Corsepius ralf.corsepius at rtems.org
Fri Jan 14 05:39:33 UTC 2005
On Thu, 2005-01-13 at 23:56 +0100, Karel Gardas wrote:
> On Thu, 13 Jan 2005, Joel Sherrill <joel at OARcorp.com> wrote:
> > Karel Gardas wrote:
> > > Hello,
> > > I've found the reason why I had these strange issues with gcc3.2.3 and
> > > rtems 4.6.2. I've found them since I've also started to have them with
> > > rtems trunk and gcc3.4.3. The reason is that we write code like:
> > > while RTEMS seems to define stringify macro:
> > >      145
> > >      146 #define stringify( _x ) # _x
> > >      147
> > That means RTEMS violates the application namespace.  That
> > should be rtems_stringify.
> True
> > But I don't see it used in RTEMS so it could be considered obsolete
> > and purged at this point.
> Should I fill PR?
I went ahead, filed a PR and kicked out stringify from rtems-4-6-branch
and cvs-trunk.
Ralf
