Problems FAT16 format..and some more
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Mon Jan 17 07:44:16 UTC 2005
Hello Daniel,
> Hello Thomas!
> I need some help :)
I'll do what I can...
> When a format 1 gb disk with Fat16 it goes corrupt. I´ve tested both cluster
> 16384 and 32768 with sector size 512. When dos_fs tries to read the volume
> information it just says invalid argument.
What happens during the "msdos_format" function? Is the return
status ok?
Let us do some computations: You have a 1GB disk, and it hast
blocks of 16384 or 32768 bytes each. This means:
1GB/16384=65536 blocks.
1GB/32768=32768 blocks.
Any disk with more than 65524 blocks is a FAT32 disk. So I would
hope, that the "format" code would either reject requested
parameters of FAT16 and 16K blocks, or it would modify your
parameters.
-> Can you set a breakpoint in the "msdos_format" function just
after the msdos_format_determine_fmt_params function call, and
inspect the contents of the fmt_params data structure?
Your second configuration, 32K blocks, should be ok as FAT16.
I have tried cluster 16384 and
> sector 512 with FAt32 and it works fine. What can this depend on?
Well, this is a proper configuration, so it SHOULD work!
> Another problem is when i try to format the disk for the second time with a
> working fat32 formatted disk. Most of the cases it seems not to do a proper
> format. Files can still be listed and some times it seems like the root
> director is not cleared?? Just garbage is shown in a list of files.
> I use the bdbuf configuration 1 so it should not be the cache that is the
> problem. If i use a large cache and do a format, the whole cache becomes
> dirty or???
dosfs keeps some internal values for each mounted disk. Did you
properly unmount your disk before calling format and mount it
again afterwards? This is VERY important to keep things working.
> Can you help me understand what those problems can depend on and tell me any
> other valuable information related to the format.???
When you still have incompatibilities between "msdos_format" and
mounting, maybe inspecting "fmt_params" and stepping through the
function "msdos_initialize_support" might give you more
insights, what goes wrong and which parameters are considered
wrong during the mount process.
I would love to see some dumps of your system, especially the
"fmt_params" structure in various configurations.
By the way: up to now I tested "msdos_format" only on big-endian
systems, so there is always the chance of a incompatibility on
little endian systems like i386.
wkr,
Thomas.
> Thanks
> Daniel Gustvsson
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
