[rtems-4-6-branch] i386/pc386 BSP compilation failure
Karel Gardas kgardas at objectsecurity.com
Mon Jan 17 09:24:52 UTC 2005
Joel,
have you been able to duplicate this build failure yourself? I've been
able to duplicate this issue also on today's rtems-4-6-branch sources, so
I'm just curious if I can submit proper bugreport now.
Thanks,
Karel
On Tue, 11 Jan 2005, Karel Gardas wrote:
> On Tue, 11 Jan 2005, Joel Sherrill <joel at OARcorp.com> wrote:
> > Karel Gardas wrote:
> > > Hello,
> > > I'm trying to compile yesterday sources from rtems-4-6-branch for pc386
> > > BSP, but build fails with:
> > > i386-rtems-gcc --pipe -B../../../../../../../lib/
> > > -B../../../../../../../pc386/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H
> > > -isystem ../../../../../../../pc386/lib/include       -O4 -g -Wall -ansi
> > > -fasm  -o o-optimize/tod.o -c
> > > ../../../../../../../../../rtems/c/src/lib/libbsp/i386/pc386/clock/../../../shared/tod.c
> > > ../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c:13:17:
> > > tod.h: No such file or directory
> > > ../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c: In
> > > function `rtc_initialize':
> > > ../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c:102:
> > > warning: implicit declaration of function `setRealTimeToRTEMS'
> > > ../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c: At top
> > > level:
> > > ../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c:119:
> > > warning: type mismatch with previous implicit declaration
> > > warning: previous implicit declaration of `setRealTimeToRTEMS'
> > > warning: `setRealTimeToRTEMS' was previously implicitly declared to return
> > > `int'
> > > make[6]: *** [o-optimize/tod.o] Error 1
> > > make[6]: Leaving directory
> > > `/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp/i386/pc386/clock'
> > > make[5]: *** [all-recursive] Error 1
> > > make[5]: Leaving directory
> > > `/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp/i386/pc386'
> > > make[4]: *** [all-recursive] Error 1
> > > make[4]: Leaving directory
> > > `/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp/i386'
> > > make[3]: *** [all-recursive] Error 1
> > > make[3]: Leaving directory
> > > `/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp'
> > > make[2]: *** [all-recursive] Error 1
> > > make[2]: Leaving directory
> > > `/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386'
> > > make[1]: *** [all-recursive] Error 1
> > > make[1]: Leaving directory
> > > `/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c'
> > > make: *** [all-recursive] Error 1
> > > gcc is configured as:
> > > thinkpad:/mnt/karel/downloads/RTEMS/build/tools/obj-rtems$ i386-rtems-gcc
> > > -v
> > > Reading specs from
> > > /mnt/karel/rtems-x86-toolchain/lib/gcc-lib/i386-rtems/3.2.3/specs
> > > Configured with: ../gcc-3.2.3/configure
> > > --prefix=/mnt/karel/rtems-x86-toolchain --target=i386-rtems --with-gnu-as
> > > --with-gnu-ld --with-newlib --verbose --enable-threads
> > > --enable-languages=c,c++
> > > Thread model: rtems
> > > gcc version 3.2.3
> > > Should I report this error to your bugtracking system?
> > Probably but before you do that.. how exactly did you configure?
> I've configured it with:
> ../rtems/configure --target=i386-rtems --enable-cxx
> --enable-rtemsbsp=pc386 --prefix=/mnt/karel/rtems-x86
> and i386-rtems tool-chain is installed in:
> Thanks,
> Karel
> ObjectSecurity Ltd.           http://www.objectsecurity.com
