[rtems-4-6-branch] i386/pc386 BSP compilation failure
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Jan 17 15:35:29 UTC 2005
Karel Gardas wrote:
> Joel,
> have you been able to duplicate this build failure yourself? I've been
> able to duplicate this issue also on today's rtems-4-6-branch sources, so
> I'm just curious if I can submit proper bugreport now.
I haven't even gotten a chance to try.  I have been battling gcc 4.x
with Ralf.
Go ahead and file the PR.
--joel
> Thanks,
> Karel
> On Tue, 11 Jan 2005, Karel Gardas wrote:
>>On Tue, 11 Jan 2005, Joel Sherrill <joel at OARcorp.com> wrote:
>>>Karel Gardas wrote:
>>>>Hello,
>>>>I'm trying to compile yesterday sources from rtems-4-6-branch for pc386
>>>>BSP, but build fails with:
>>>>i386-rtems-gcc --pipe -B../../../../../../../lib/
>>>>-B../../../../../../../pc386/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H
>>>>-isystem ../../../../../../../pc386/lib/include       -O4 -g -Wall -ansi
>>>>-fasm  -o o-optimize/tod.o -c
>>>>../../../../../../../../../rtems/c/src/lib/libbsp/i386/pc386/clock/../../../shared/tod.c
>>>>../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c:13:17:
>>>>tod.h: No such file or directory
>>>>../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c: In
>>>>function `rtc_initialize':
>>>>../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c:102:
>>>>warning: implicit declaration of function `setRealTimeToRTEMS'
>>>>../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c: At top
>>>>level:
>>>>../../../../../../../../../rtems/c/src/lib/libbsp/shared/tod.c:119:
>>>>warning: type mismatch with previous implicit declaration
>>>>warning: previous implicit declaration of `setRealTimeToRTEMS'
>>>>warning: `setRealTimeToRTEMS' was previously implicitly declared to return
>>>>`int'
>>>>make[6]: *** [o-optimize/tod.o] Error 1
>>>>make[6]: Leaving directory
>>>>`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp/i386/pc386/clock'
>>>>make[5]: *** [all-recursive] Error 1
>>>>make[5]: Leaving directory
>>>>`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp/i386/pc386'
>>>>make[4]: *** [all-recursive] Error 1
>>>>make[4]: Leaving directory
>>>>`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp/i386'
>>>>make[3]: *** [all-recursive] Error 1
>>>>make[3]: Leaving directory
>>>>`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386/lib/libbsp'
>>>>make[2]: *** [all-recursive] Error 1
>>>>make[2]: Leaving directory
>>>>`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c/pc386'
>>>>make[1]: *** [all-recursive] Error 1
>>>>make[1]: Leaving directory
>>>>`/mnt/karel/downloads/RTEMS/build/tools/obj-rtems/i386-rtems/c'
>>>>make: *** [all-recursive] Error 1
>>>>gcc is configured as:
>>>>thinkpad:/mnt/karel/downloads/RTEMS/build/tools/obj-rtems$ i386-rtems-gcc
>>>>-v
>>>>Reading specs from
>>>>/mnt/karel/rtems-x86-toolchain/lib/gcc-lib/i386-rtems/3.2.3/specs
>>>>Configured with: ../gcc-3.2.3/configure
>>>>--prefix=/mnt/karel/rtems-x86-toolchain --target=i386-rtems --with-gnu-as
>>>>--with-gnu-ld --with-newlib --verbose --enable-threads
>>>>--enable-languages=c,c++
>>>>Thread model: rtems
>>>>gcc version 3.2.3
>>>>Should I report this error to your bugtracking system?
>>>Probably but before you do that.. how exactly did you configure?
>>I've configured it with:
>>../rtems/configure --target=i386-rtems --enable-cxx
>>--enable-rtemsbsp=pc386 --prefix=/mnt/karel/rtems-x86
>>and i386-rtems tool-chain is installed in:
>>Thanks,
>>Karel
>>Karel Gardas                  kgardas at objectsecurity.com
>>ObjectSecurity Ltd.           http://www.objectsecurity.com
