signal/kill calls
Smith, Gene gene.smith at siemens.com
Tue Jan 18 16:15:17 UTC 2005
Smith, Gene wrote, On 1/17/2005 3:17 PM:
> The application which I am porting makes a posix style signal() and
> kill() call in the code. The application itself does not define these
> function. But when I link against rtems, kill() is resolved while
> signal() is not. I did not configure my rtems install with
> --enable-posix. Anyone know right off where the kill() could be coming
> from? Don't see it in libc.a with rtems-objdump.
> -gene
I reconfigured rtems with --enable-posix added and now the call to
signal() resolves OK too. Is it OK to mix posix and standard RTEMS calls
in the same application?
-gene
