printf in interrupt handlers
Jiri Gaisler
jiri at gaisler.com
Thu Jan 20 11:09:42 UTC 2005
Simple question: is printf in interrupt handlers allowed?
It is not that I really want to do a printf in an interrupt
handler, but when I tried it, RTEMS halts with
Internal_error_Occurred(). This behaviour started on rtems-4.6,
the earlier rtmes-4.5 could do a printf from an interrupt
handler without problems. I am trying this on the SPARC
(ERC32/LEON) target. The back trace after the error is:
%pc %sp
#0 0x40002d7c 0x403ff350 _Internal_error_Occurred + 0x40
#1 0x40007120 0x403ff3b8 rtems_semaphore_obtain + 0x11c
#2 0x400083b4 0x403ff428 rtems_termios_write + 0x18
#3 0x400032a8 0x403ff490 rtems_io_write + 0x4c
#4 0x400113d8 0x403ff4f8 device_write + 0x30
#5 0x4001ba34 0x403ff578 write + 0x90
#6 0x40012d74 0x403ff5e0 fflush + 0x8c
#7 0x40018068 0x403ff648 __sfvwrite + 0x350
#8 0x40014ba0 0x403ff6b0 _vfiprintf_r + 0xe7c
#9 0x400163c8 0x403ff718 _vfprintf_r + 0x16f8
#10 0x40013354 0x403ff9a0 printf + 0x2c
#11 0x4000285c 0x403ffa08 _ISR_Handler + 0x130
#12 0x40001228 0x403f8818 Init + 0x2c
#13 0x400129f0 0x403f8938 _Thread_Handler + 0x110
#14 0x400128d8 0x403f89a0 memfile_check_rmnod + 0x70
A bit debugging shows that rtems_semaphore_obtain() fails for
some reason and Internal_error_Occurred is called. It does not
seem to be a stack problem - I have increased the interrupt stack
to 256 kbyte as a test.
Jiri Gaisler.
Gaisler Research, 1:a Långgatan 19, 413 27 Goteborg, Sweden, +46-317758650
fax: +46-31421407 email: info at gaisler.com, home page: www.gaisler.com
