signal/kill calls
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Jan 21 12:09:59 UTC 2005
Smith, Gene wrote:
> Joel Sherrill <joel at OARcorp.com> wrote, On 1/18/2005 11:32 AM:
>> Smith, Gene wrote:
>>> Smith, Gene wrote, On 1/17/2005 3:17 PM:
>>>> The application which I am porting makes a posix style signal() and
>>>> kill() call in the code. The application itself does not define
>>>> these function. But when I link against rtems, kill() is resolved
>>>> while signal() is not. I did not configure my rtems install with
>>>> --enable-posix. Anyone know right off where the kill() could be
>>>> coming from? Don't see it in libc.a with rtems-objdump.
>>>> -gene
>>> I reconfigured rtems with --enable-posix added and now the call to
>>> signal() resolves OK too. Is it OK to mix posix and standard RTEMS
>>> calls in the same application?
>> Most definitely. :)  It was designed long ago to do this.
> In init.c I did not define any CONFIGURE_MAXIMUM_POSIX_... items so it
> seem it should use defaults for these (all zero). Yet when I run the
> code it fails due to a large (uninitialized?) value for
> api_configuration->maximum_queued_signals in posixapi.c because
> api_configuration never gets set to &_POSIX_Default_configuration, I think.
> So I guess my question is how do you configure a system that will use
> 99.99% Classic API and just a little posix?
For this use of POSIX, it should be sufficient to just
use an RTEMS built with --enable-posix.
Do you have a small test case?
