Clock ticks
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Jan 21 13:51:31 UTC 2005
Daniel Gustafsson wrote:
> We are using ERC32 with 20Mhz but don't get the right timing. What shall
> CONFIGURE_MICROSECONDS_PER_TICK be in our system?
Check the value of _CLOCK_SPEED when it is being set in boardinit.S
from this BSP.  It appears to default to 14 to indicate 14 Mhz.
--joel
> //Daniel
>>-----Original Message-----
>>From: Joel Sherrill <joel at OARcorp.com>
>>[mailto:joel.sherrill at OARcorp.com]
>>Sent: Friday, January 21, 2005 1:21 PM
>>To: Ralf Corsepius
>>Cc: Daniel Gustafsson; RTEMS Users
>>Subject: Re: Clock ticks
>>Ralf Corsepius wrote:
>>>On Fri, 2005-01-21 at 10:52 +0100, Daniel Gustafsson wrote:
>>>>How do I inform Rtems 4.6.2 that I am running on a 20Mhz CPU.
>>>>I've tried to alter MICRO_SECONDS_PER_TICK but i can't
>>figure out how it is
>>>>done properly (correct value).
>>>It's highly BSP and target specific. Which target, which BSP are you
>>>using?
>>If memory servers, they are on a SPARC/ERC32.  It should work
>>because the BSP will do math in the clock driver to convert the
>>configured value into the value used to program the timer.
>>The constant you are using should be CONFIGURE_MICROSECONDS_PER_TICK
>>and it should be set BEFORE you include confdefs.h.
>>--joel
