Manual typo regarding ITRON?
Smith, Gene gene.smith at siemens.com
Fri Jan 21 17:06:58 UTC 2005
The Rtems C users manual (all versions I checked, including 4.6.2)
states this:
--------------- quote -----------------
22.2.9 ITRON API Configuration
The parameters in this section are used to configure resources for the
RTEMS ITRON API. They are only relevant if the POSIX API is enabled at
configure time using the --enable-itron option.
----------------- end quote -------------
It reads the "POSIX API is enabled" where I think it should read "ITRON
API is enabled." Also, ITRON API, at least for target powerpc-rtems,
defaults to enabled unless explicitly disabled with --disable-itron.
Same for POSIX API per README.configure. User manual should possibly
refer users to this file regarding API defaults.
-gene
