Clock ticks
Daniel Gustafsson daniel.gustafsson at space.se
Mon Jan 24 06:58:41 UTC 2005
I tried to change _CLOCK_SPEED in boardinit.S from 14 to 20 but nothing
happens (have done a "make all install"). The timing is still wrong. Any
ideés?
//Daniel
>-----Original Message-----
>From: Joel Sherrill <joel at OARcorp.com>
>[mailto:joel.sherrill at OARcorp.com]
>Sent: Friday, January 21, 2005 2:52 PM
>To: Daniel Gustafsson; rtems-users at rtems.com
>Subject: Re: Clock ticks
>Daniel Gustafsson wrote:
>> We are using ERC32 with 20Mhz but don't get the right
>timing. What shall
>> CONFIGURE_MICROSECONDS_PER_TICK be in our system?
>Check the value of _CLOCK_SPEED when it is being set in boardinit.S
>from this BSP.  It appears to default to 14 to indicate 14 Mhz.
>--joel
>> //Daniel
>>>Sent: Friday, January 21, 2005 1:21 PM
>>>To: Ralf Corsepius
>>>Cc: Daniel Gustafsson; RTEMS Users
>>>Ralf Corsepius wrote:
>>>>On Fri, 2005-01-21 at 10:52 +0100, Daniel Gustafsson wrote:
>>>>>How do I inform Rtems 4.6.2 that I am running on a 20Mhz CPU.
>>>>>I've tried to alter MICRO_SECONDS_PER_TICK but i can't
>>>figure out how it is
>>>>>done properly (correct value).
>>>>It's highly BSP and target specific. Which target, which BSP are you
>>>>using?
>>>If memory servers, they are on a SPARC/ERC32.  It should work
>>>because the BSP will do math in the clock driver to convert the
>>>configured value into the value used to program the timer.
>>>The constant you are using should be CONFIGURE_MICROSECONDS_PER_TICK
>>>and it should be set BEFORE you include confdefs.h.
>>>--joel
>Joel Sherrill, Ph.D.             Director of Research & Development
>joel at OARcorp.com                 On-Line Applications Research
>Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>    Support Available             (256) 722-9985
