Clock ticks
Daniel Gustafsson daniel.gustafsson at space.se
Mon Jan 24 12:24:12 UTC 2005
I forgot to tell you that I did "make clean" before doing "make all install"
and it still did not work.
I found a line in sparc/shared/start.S that said 10 MHz default. Have
changed this value and done a rebuild. This seams to work fine.
//Daniel
>-----Original Message-----
>From: Joel Sherrill <joel at OARcorp.com>
>[mailto:joel.sherrill at OARcorp.com]
>Sent: Monday, January 24, 2005 1:16 PM
>To: Daniel Gustafsson
>Cc: rtems-users at rtems.com
>Subject: Re: Clock ticks
>Daniel Gustafsson wrote:
>> I tried to change _CLOCK_SPEED in boardinit.S from 14 to 20
>but nothing
>> happens (have done a "make all install"). The timing is
>still wrong. Any
>> ideés?
>linkcmds is not a dependency on relinking.
>cd build
>rm -f `find . -name "*.exe"`
>make all install
>--joel
>> //Daniel
>>>Sent: Friday, January 21, 2005 2:52 PM
>>>To: Daniel Gustafsson; rtems-users at rtems.com
>>>>We are using ERC32 with 20Mhz but don't get the right
>>>timing. What shall
>>>>CONFIGURE_MICROSECONDS_PER_TICK be in our system?
>>>Check the value of _CLOCK_SPEED when it is being set in boardinit.S
>>>from this BSP.  It appears to default to 14 to indicate 14 Mhz.
>>>--joel
>>>>//Daniel
>>>>>Sent: Friday, January 21, 2005 1:21 PM
>>>>>To: Ralf Corsepius
>>>>>Cc: Daniel Gustafsson; RTEMS Users
>>>>>Ralf Corsepius wrote:
>>>>>>On Fri, 2005-01-21 at 10:52 +0100, Daniel Gustafsson wrote:
>>>>>>>How do I inform Rtems 4.6.2 that I am running on a 20Mhz CPU.
>>>>>>>I've tried to alter MICRO_SECONDS_PER_TICK but i can't
>>>>>figure out how it is
>>>>>>>done properly (correct value).
>>>>>>It's highly BSP and target specific. Which target, which
>BSP are you
>>>>>>using?
>>>>>If memory servers, they are on a SPARC/ERC32.  It should work
>>>>>because the BSP will do math in the clock driver to convert the
>>>>>configured value into the value used to program the timer.
>>>>>The constant you are using should be
>>>>>and it should be set BEFORE you include confdefs.h.
>>>>>--joel
>>>Joel Sherrill, Ph.D.             Director of Research & Development
>>>joel at OARcorp.com                 On-Line Applications Research
>>>Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>   Support Available             (256) 722-9985
