[PATCH] pc386 BSP PCI initialization fix [was: Re: PCI lookup issue: 3c905C-TX not found by RTEMS.]
Karel Gardas
kgardas at objectsecurity.com
Tue Jan 25 16:47:30 UTC 2005
Hello,
thanks to help provided by Gregory Menke, I was finally able to get my
K6-2/3c905C-TX NIC machine working with RTEMS. As a result of my debug
trip thorough pcibios/elnk.c sources, I've created attached patch. It adds
some more verbose debugging when PCI_DEBUG is defined and fixes pci
initialization by directly calling pcib_init from BSP_pciFindDevice in
case PCI is not yet initialized. I've also tested applying it to the trunk
and it has gone well.
Thanks,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
Index: c/src/lib/libbsp/i386/shared/pci/pcibios.c
RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/i386/shared/pci/pcibios.c,v
retrieving revision 1.3.2.2
diff -u -r1.3.2.2 pcibios.c
--- c/src/lib/libbsp/i386/shared/pci/pcibios.c 27 Sep 2004 21:49:18 -0000 1.3.2.2
+++ c/src/lib/libbsp/i386/shared/pci/pcibios.c 25 Jan 2005 15:52:56 -0000
@@ -18,6 +18,7 @@
* is flat and that stack is big enough
+/* #define PCI_DEBUG 1 */
static int pcibInitialized = 0;
static unsigned int pcibEntry;
@@ -39,6 +40,9 @@
int
pcib_init(void)
+#ifdef PCI_DEBUG
+ printk("PCI bus init\n");
+#endif /* PCI_DEBUG */
unsigned char *ucp;
unsigned char sum;
int i;
@@ -80,6 +84,9 @@
/* BIOS-32 found, let us find PCI BIOS */
+#ifdef PCI_DEBUG
+ printk("BIOS-32 found, let us find PCI BIOS\n");
ucp += 4;
pcibExchg[0] = *(unsigned int *)ucp;
@@ -103,6 +110,9 @@
/* Found PCI entry point */
+#ifdef PCI_DEBUG
+ printk("Found PCI entry point\n");
pcibEntry = pcibExchg[1] + pcibExchg[3];
/* Let us check whether PCI bios is present */
@@ -123,17 +133,26 @@
if((pcibExchg[0] & 0xff00) != 0)
/* Not found */
+#ifdef PCI_DEBUG
+ printk("PCI BIOS not found!\n");
return PCIB_ERR_NOTPRESENT;
if(pcibExchg[3] != 0x20494350)
/* Signature does not match */
+#ifdef PCI_DEBUG
+ printk("PCI BIOS not found: signature does not match!\n");
/* Success */
+#ifdef PCI_DEBUG
+ printk("Found PCI BIOS\n");
pcibInitialized = 1;
return PCIB_ERR_SUCCESS;
@@ -231,6 +250,9 @@
int
BusCountPCI()
+#ifdef PCI_DEBUG
+ printk("BusCountPCI: ");
if( ucBusCount == 0xff )
unsigned char bus,dev,hd;
@@ -272,8 +294,10 @@
printk("BusCountPCI() found 0xff busses, assuming 1\n");
ucBusCount = 1;
+#ifdef PCI_DEBUG
+ printk("%d\n", ucBusCount);
return ucBusCount;
@@ -285,8 +309,16 @@
unsigned int d;
unsigned short s;
unsigned char bus,dev,fun,hd;
+ int bus_count;
+ if(!pcibInitialized)
+ pcib_init();
- for (bus=0; bus<BusCountPCI(); bus++)
+ bus_count = BusCountPCI();
+ for (bus=0; bus<bus_count; bus++)
for (dev=0; dev<PCI_MAX_DEVICES; dev++)
@@ -313,11 +345,17 @@
#endif
/* pci_read_config_word(bus,dev,fun,PCI_VENDOR_ID,&s); */
pcib_conf_read16(sig, 0, &s);
+#ifdef PCI_DEBUG
+ printk("found vendor: %x at %d/%d/%d\n",s,bus,dev,fun);
+#endif
if (vendorid != s)
continue;
/* pci_read_config_word(bus,dev,fun,PCI_DEVICE_ID,&s); */
pcib_conf_read16(sig, 0x2, &s);
+#ifdef PCI_DEBUG
+ printk("found device id: %x at %d/%d/%d\n",s,bus,dev,fun);
+#endif
if (deviceid == s) {
if (instance--) continue;
*pbus=bus;
