[PATCH] pc386 BSP PCI initialization fix [was: Re: PCI lookup issue: 3c905C-TX not found by RTEMS.]
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Tue Jan 25 17:07:31 UTC 2005
Karel Gardas writes:
 > Hello,
 > thanks to help provided by Gregory Menke, I was finally able to get my
 > K6-2/3c905C-TX NIC machine working with RTEMS. As a result of my debug
 > trip thorough pcibios/elnk.c sources, I've created attached patch. It adds
 > some more verbose debugging when PCI_DEBUG is defined and fixes pci
 > initialization by directly calling pcib_init from BSP_pciFindDevice in
 > case PCI is not yet initialized. I've also tested applying it to the trunk
 > and it has gone well.
I think calling pcib_init in this way is probably not the best idea
for a long-term fix.  Thought he fact that it works suggests theres a
bug in the pc386 bsp startup.  Is there an active maintainer for the
pc386 family?
Gregm
