c++ libs in bsp_spec file?
Smith, Gene
gene.smith at siemens.com
Thu Jan 6 19:05:34 UTC 2005
Ralf Corsepius wrote, On 1/6/2005 12:01 PM:
> On Thu, 2005-01-06 at 11:17 -0500, Smith, Gene wrote:
>>I am 99% sure that I configured my ppc405 based bsp with the flag
>>--enable-cxx. However, when I linked my app containing several c++
>>modules I got undefined references to "operator delete[]" and other
>>c++ish things. I noticed that my installed bap_specs file contained no
>>"++" libraries listed. So I manually added -lstdc++ and -lrtems++ to the
>>*lib: area of bsp_specs and it fixed the link errors. Should these ++
>>libraries appear automatically in bsp_specs
> Definitely no.
>> when the project is
>>configured with c++ or do these typically have to be manually included
>>in bsp_specs file?
> Neither. You have to use "g++" instead of "gcc" to link. Explicitly
> specifying -lstdc++ on the link command line or inside of a spec file
> (which is more or less equivalent to using the command-line) is fault.
> If this doesn't work, something else is broken.
> Ralf
Yes, g++ as linker works with no change to bsp_specs. Thanks for info!
-gene
