Abatron BDI2000 / Powerpc-rtems.
Mark Dean M.Dean at sstl.co.uk
Mon Jan 10 14:18:24 UTC 2005
Joel,
   Jus to let you know that you were right. Everything works fine with the BDI2000 now that I have removed the low-power mode from our idle task.
   cheers,
      Mark.
-----Original Message-----
[mailto:joel.sherrill at OARcorp.com]
Sent: 07 January 2005 12:21
To: Mark Dean
Cc: Rtems-Users (E-mail)
Subject: Re: Abatron BDI2000 / Powerpc-rtems.
Mark Dean wrote:
> forgot to send to the list too...
> From: Mark Dean
> Sent: 07 January 2005 08:55
> To: 'Steve Holle'
> Subject: RE: Abatron BDI2000 / Powerpc-rtems.
> Yeah, I know. But the watchdog is disabled. I can remove/add code so that the time to the idle section of the application changes and every time it crashes as soon as the application finishes processing and goes idle...
What does the idle thread do in this configuration?
On some CPU models, it enters low power mode and this
may negatively impact the BDI2000 although it shouldn't.
If this is the case, disable the CPU model or BSP
specific Idle thread and go back to the portable
branch to self version.
--joel
> From: Steve Holle [mailto:sholle at link-comm.com]
> Sent: 06 January 2005 17:56
> To: Mark Dean; Rtems-Users (E-mail)
> Sounds like a watchdog.
> At 09:00 AM 1/6/2005, Mark Dean wrote:
>>Anyone seen a problem with the Abatron BDI2000 where when there are no
>>user tasks running it halts the processor then when I try to 'continue'
>>the board resets? Its very odd, without the BDI connected everything is
>>totally fine. I'm also able to set breakpoints, examine source code,
>>registers, memory etc. etc. in the normal way. It just falls over when my
>>application tasks are all idle. This makes me think its having a problem
>>way down at the RTEMS level somewhere.
>>   Cheers,
>>      Mark.
> Steve Holle
> Link Communications, Inc.
> 1035 Cerise Rd.
> Billings, MT  59101
