GCC 3.4.x + RTEMS 4.6.2 release.
Karel Gardas
kgardas at objectsecurity.com
Thu Jan 13 14:52:27 UTC 2005
First of all, thanks Joel and Ralf for really important information!
On Thu, 13 Jan 2005, Joel Sherrill <joel at OARcorp.com> wrote:
> Agreed ...gcc 3.3.x seems pretty OK. All gcc versions have bugs, it
> is just a matter of if it one you care about. :)
As long as compiled MICO passes its testuite, I don't care about gcc bugs
at all. :-)
Joel:
> RTEMS exposes bugs in GCC 3.4.x. I think we have reported the
> ones we trigger building the toolset and RTEMS. However, it is
> late in the gcc 3.4 lifecycle and effort expended pushing on it
> gets better results pushing at 4.0. Often the fix gets backported
> anyway.
Ralf:
> > For development, I am currently using
> > * binutils-2.15 w/o any patches.
> > * GCC-3.4-branch and GCC-HEAD (aka. GCC-4.0) without any patches rsp.
> > with local patches I am planning to commit to GCC in near future
> > applied.
> > * newlib-CVS + the newlib-patch I sent to this list a couple of days ago
> > applied.
Now, I will give a Ralf's combination a try, with the exception of using
just plain 3.4.3 compiler. If it does not work, I will move to 3.3.x or
eventually to 4.0.0 depending on if the required patches are commited.
> + i386-rtems has a soft-float compiler error. We have a
> PR and the information for a solution. Richard Henderson
> made a suggestion yesterday on a better fix, we need to
> decipher and implement.
Hmm, AFIAK soft-float is not used on pc386 BSP, isn't it? If it is not
then this should not affect me...
> + sparc-rtems did not build. I think I have this fixed but
> suspect the sparc reorg in gcc and my update changed the
> C++ ctor method for RTEMS.
> + Ralf reported a m68k-rtems compiler error with paranoia.
I hope these do not affect x86 platform. BTW: I'm using Qemu for RTEMS
running now.
Thanks,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
