GCC 3.4.x + RTEMS 4.6.2 release.
Karel Gardas
kgardas at objectsecurity.com
Thu Jan 13 16:02:59 UTC 2005
On Thu, 13 Jan 2005, Ralf Corsepius wrote:
> On Thu, 2005-01-13 at 15:52 +0100, Karel Gardas wrote:
> > First of all, thanks Joel and Ralf for really important information!
> > > + i386-rtems has a soft-float compiler error.
> gcc >= 4.0.0, gcc < 4.0 should not be affected.
Why `=' here?
> > If it is not
> > then this should not affect me...
> It would affect you, because current GCC-4.0.0 will not build.
True, now I see during the build of 3.4.3 that it also builds soft-float
libs, where 4.0.0 would probably choke...
> > > + sparc-rtems did not build. I think I have this fixed but
> > > suspect the sparc reorg in gcc and my update changed the
> > > C++ ctor method for RTEMS.
> > > + Ralf reported a m68k-rtems compiler error with paranoia.
> This applies to gcc-4.0.0
Yes, I understand.
Thanks,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
