wchar/wstring support in C++
Karel Gardas
kgardas at objectsecurity.com
Thu Jan 13 18:22:49 UTC 2005
Hello,
just for the record I will reply to myself. I've investigated a bit why
even when using gcc3.4.3/newlib1.13 combination wchar/wstring support in
libstdc++ is still disabled. The reason is this code in libstdc++'s
aclocal.m4 file:
# At the moment, only enable wchar_t specializations if all the
# above support is present.
if test x"$ac_isoC99_wchar_t" = xyes &&
test x"$ac_XPG2_wchar_t" = xyes;
then
AC_DEFINE(_GLIBCXX_USE_WCHAR_T)
enable_wchar_t=yes
fi
at least ac_isoC99_wchar_t == no here, since underlaying newlib does not
provide enhanced C99 wchar support, i.e. functions: wcstold, wcstoll,
wcstoull.
For basic MICO[1] port, missing wchar/wstring support is not showstopper,
so I will now postpone workarounding this "issue" with some ugly hack, but
for later port of OpenPMF[2] missing wstring is indeed an issue, so I will
get back to this hopefully in the future.
Cheers,
Karel
[1]: http://www.mico.org
[2]: http://www.openpmf.org
On Tue, 11 Jan 2005, Karel Gardas wrote:
> Hello,
> it seems that 4.6.2 release tool-chain does not support wchar/wstring
> types in C++ language (libstdc++). On the other hand it seems that
> underlaying newlib supports needed wchar.h header and functions
> definitions. Is there any trick how to make wchar/wstring support working
> in libstdc++?
> Thanks,
> Karel
> Karel Gardas kgardas at objectsecurity.com
> ObjectSecurity Ltd. http://www.objectsecurity.com
