stringify macro issue [was: Re: GCC 3.4.x + RTEMS 4.6.2 release.]
Karel Gardas
kgardas at objectsecurity.com
Thu Jan 13 22:56:12 UTC 2005
On Thu, 13 Jan 2005, Joel Sherrill <joel at OARcorp.com> wrote:
> Karel Gardas wrote:
> > Hello,
> > I've found the reason why I had these strange issues with gcc3.2.3 and
> > rtems 4.6.2. I've found them since I've also started to have them with
> > rtems trunk and gcc3.4.3. The reason is that we write code like:
> > class Foo
> > std::string stringify () const;
> > while RTEMS seems to define stringify macro:
> > 145
> > 146 #define stringify( _x ) # _x
> > 147
> That means RTEMS violates the application namespace. That
> should be rtems_stringify.
True
> But I don't see it used in RTEMS so it could be considered obsolete
> and purged at this point.
Should I fill PR?
Thanks,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
