vsnprintf
Ralf Corsepius
ralf.corsepius at rtems.org
Fri Jan 14 09:21:52 UTC 2005
On Thu, 2005-01-13 at 13:00 -0700, Steve Holle wrote:
> That did the trick. I just put a prototype in the file with the problem
> and was able to compile without problems.
Well, of cause you can do this, but ... this is a "dirty hack".
The error you are seeing actually indicates this package having a
configuration problem which ought to be fixed, instead of being worked-
around like you did.
Ralf
