listen/select and then accept pattern not working?
Karel Gardas
kgardas at objectsecurity.com
Fri Jan 14 20:27:01 UTC 2005
On Fri, 14 Jan 2005, Steve Holle wrote:
> We are using select on a telnet server. If you would like to have the full
> source let me know. This is how we use it
Thanks for your kind offer, however I don't know if your telnet server
uses the same pattern like MICO does. Anyway, could you be so kind and
test my select on listening socket test which I'm just going to send to
this mailing list?
Thanks,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
