PCI lookup issue: 3c905C-TX not found by RTEMS.
Karel Gardas kgardas at objectsecurity.com
Tue Jan 18 21:25:21 UTC 2005
On Tue, 18 Jan 2005, Karel Gardas wrote:
> Till,
> yes, while looking for a set of supported NICs, I've also found your
> excelent jumbo patch against 4.6.2 (your site seems to be the only one
> noting RTEMS in conjuction with Etherexpress and 3c90x :-)). I've tested
> exactly this code below, but w/o success. My NIC is still not findable...
> So for debugging and reporting to rtems-users I've came back to original
> code. Anyway, since I'm not 100% sure (just 99% sure) that I've done all
> the steps right (i.e recompile rtems, copy *.a, relink server.exe, copy
> server.exe), I will give your code a try again in a few minutes.
I've tested your code again right now, and it is also not able to find my
card. Debug messages claim that BSP_pciFindDevice function returns -1 for
every 3com tested NIC including my 10b7/9200.
BTW: Just for the record, there were several OSes installed in this box
with this card and all does not have any issue with it: RedHat 9, Debian
GNU/Linux 3.0, OpenBSD 3.4, FreeBSD 4.7 (still installed and used for
uploading RTEMS images). -- so I think pci/pcibios is functional there...
Thanks,
Karel
ObjectSecurity Ltd.           http://www.objectsecurity.com
