printf in interrupt handlers
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Thu Jan 20 12:39:27 UTC 2005
Jiri Gaisler wrote:
> Simple question: is printf in interrupt handlers allowed?
> It is not that I really want to do a printf in an interrupt
> handler, but when I tried it, RTEMS halts with
> Internal_error_Occurred(). This behaviour started on rtems-4.6,
> the earlier rtmes-4.5 could do a printf from an interrupt
> handler without problems. I am trying this on the SPARC
> (ERC32/LEON) target. The back trace after the error is:
It was always a mistake to do it and could have been disastrous
in random and unforeseen ways. It is not explicitly checked
that you are printing. It is a check on a flavor of mutex being
used from an ISR. If you are priority ceiling or priority
inheritance or blocking, you can't do that from an ISR.
> %pc %sp
> #0 0x40002d7c 0x403ff350 _Internal_error_Occurred + 0x40
> #1 0x40007120 0x403ff3b8 rtems_semaphore_obtain + 0x11c
> #2 0x400083b4 0x403ff428 rtems_termios_write + 0x18
> #3 0x400032a8 0x403ff490 rtems_io_write + 0x4c
> #4 0x400113d8 0x403ff4f8 device_write + 0x30
> #5 0x4001ba34 0x403ff578 write + 0x90
> #6 0x40012d74 0x403ff5e0 fflush + 0x8c
> #7 0x40018068 0x403ff648 __sfvwrite + 0x350
> #8 0x40014ba0 0x403ff6b0 _vfiprintf_r + 0xe7c
> #9 0x400163c8 0x403ff718 _vfprintf_r + 0x16f8
> #10 0x40013354 0x403ff9a0 printf + 0x2c
> #11 0x4000285c 0x403ffa08 _ISR_Handler + 0x130
> #12 0x40001228 0x403f8818 Init + 0x2c
> #13 0x400129f0 0x403f8938 _Thread_Handler + 0x110
> #14 0x400128d8 0x403f89a0 memfile_check_rmnod + 0x70
> A bit debugging shows that rtems_semaphore_obtain() fails for
> some reason and Internal_error_Occurred is called. It does not
> seem to be a stack problem - I have increased the interrupt stack
> to 256 kbyte as a test.
> Jiri Gaisler.
joel at OARcorp.com On-Line Applications Research
