signal/kill calls
Smith, Gene
gene.smith at siemens.com
Fri Jan 21 14:34:19 UTC 2005
Joel Sherrill <joel at OARcorp.com> wrote, On 1/21/2005 7:09 AM:
>>So I guess my question is how do you configure a system that will use
>>99.99% Classic API and just a little posix?
> For this use of POSIX, it should be sufficient to just
> use an RTEMS built with --enable-posix.
> Do you have a small test case?
The only reason I did --enable-posix was a isolated unresolved call to
signal() in the code I am porting. Right now I am not sure that is even
called in the context in which I will be running. I will deal with it
when (if) it comes up. Thanks,
-gene
