Clock ticks
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Mon Jan 24 12:15:36 UTC 2005
Daniel Gustafsson wrote:
> I tried to change _CLOCK_SPEED in boardinit.S from 14 to 20 but nothing
> happens (have done a "make all install"). The timing is still wrong. Any
> ideés?
linkcmds is not a dependency on relinking.
cd build
rm -f `find . -name "*.exe"`
make all install
--joel
> //Daniel
>>-----Original Message-----
>>From: Joel Sherrill <joel at OARcorp.com>
>>[mailto:joel.sherrill at OARcorp.com]
>>Sent: Friday, January 21, 2005 2:52 PM
>>To: Daniel Gustafsson; rtems-users at rtems.com
>>Subject: Re: Clock ticks
>>>We are using ERC32 with 20Mhz but don't get the right
>>timing. What shall
>>>CONFIGURE_MICROSECONDS_PER_TICK be in our system?
>>Check the value of _CLOCK_SPEED when it is being set in boardinit.S
>>from this BSP. It appears to default to 14 to indicate 14 Mhz.
>>--joel
>>>//Daniel
>>>>Sent: Friday, January 21, 2005 1:21 PM
>>>>To: Ralf Corsepius
>>>>Cc: Daniel Gustafsson; RTEMS Users
>>>>Ralf Corsepius wrote:
>>>>>On Fri, 2005-01-21 at 10:52 +0100, Daniel Gustafsson wrote:
>>>>>>How do I inform Rtems 4.6.2 that I am running on a 20Mhz CPU.
>>>>>>I've tried to alter MICRO_SECONDS_PER_TICK but i can't
>>>>figure out how it is
>>>>>>done properly (correct value).
>>>>>It's highly BSP and target specific. Which target, which BSP are you
>>>>>using?
>>>>If memory servers, they are on a SPARC/ERC32. It should work
>>>>because the BSP will do math in the clock driver to convert the
>>>>configured value into the value used to program the timer.
>>>>The constant you are using should be CONFIGURE_MICROSECONDS_PER_TICK
>>>>and it should be set BEFORE you include confdefs.h.
>>>>--joel
>>Joel Sherrill, Ph.D. Director of Research & Development
>>joel at OARcorp.com On-Line Applications Research
>>Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
