Linking problem while building RTEMS-4.6.2 'pc386' under Cygwin
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Tue Jan 25 16:40:52 UTC 2005
Mills, John M. wrote:
> Hello -
> I expect this is a FAQ, but I just got bitten.
> I built and installed 'i386-rtems' tools under Cygwin, then built
> RTEMS-4.6.2 for the 'pc386' BSP. It appeared to build the components
> successfully, but the build crashes when it tries to link the samples. There
> appears to be a conflict in 'linkcmds' mapping. My error message is:
>>>>>>>the target: <<<<<<
> Making install in hello
> make[5]: Entering directory
> `/tmp/build/rtems/i386-rtems/c/pc386/tests/samples/hello'
> i386-rtems-gcc --pipe -B../../../../../lib/ -B../../../../../pc386/lib/
> -specs bsp_specs -qrtems -O4 -g -Wall -ansi -fasm
> -Wl,-Ttext,0x00100000
> -o o-optimize/hello.obj o-optimize/init.o
> ../../../../../pc386/lib/no-dpmem.rel
> ../../../../../pc386/lib/no-event.rel ../../../../../pc386/lib/no-msg.rel
> ../../../../../pc386/lib/no-mp.rel ../../../../../pc386/lib/no-part.rel
> ../../../../../pc386/lib/no-signal.rel
> ../../../../../pc386/lib/no-timer.rel
> ../../../../../pc386/lib/no-rtmon.rel
>>>>>>and the error: <<<<<<
> /opt/rtems-4.6/lib/gcc-lib/i386-rtems/3.3.5/../../../../i386-rtems/bin/ld:
> section .bss [0011a140 -> 0011d26b] overlaps section .jcr [0011a140 ->
> 0011a143]
> collect2: ld returned 1 exit status
> make[5]: *** [o-optimize/hello.exe] Error 1
Not a FAQ but a recurring issue with different section names as gcc adds
new sections. :-)
This is a new section added with gcc 3.3.x. The CVS trunk has this
patch to the linkcmds file:
$ diff -u
/usr1/rtems/4.6-work/rtems/c/src/lib/libbsp/i386/pc386/startup/linkcmds
/usr1/rtems/work/rtems/c/src/lib/libbsp/i386/pc386/startup/linkcmds
--- /usr1/rtems/4.6-work/rtems/c/src/lib/libbsp/i386/pc386/startup/linkcmds
Thu Sep 4 13:44:04 2003
+++ /usr1/rtems/work/rtems/c/src/lib/libbsp/i386/pc386/startup/linkcmds
Sun Jul 25 09:21:43 2004
@@ -28,7 +28,7 @@
| * http://www.rtems.com/license/LICENSE.
-| $Id: linkcmds,v 1.14.2.1 2003/09/04 18:44:04 joel Exp $
+| $Id: linkcmds,v 1.16 2004/07/25 14:21:43 joel Exp $
@@ -82,6 +82,7 @@
*(.gnu.linkonce.r*)
_erodata = ALIGN( 0x10 ) ;
+ *(.jcr)
_etext = ALIGN( 0x10 ) ;
> TIA for any guidance.
> John M. Mills
> Staff Engineer
> EMS Technologies
> 660 Engineering Drive
> Norcross, GA 30092
> 770.263.9200 ext4882
joel at OARcorp.com On-Line Applications Research
