Enrty point in the Task Control Block
Ali Asgar Nasir aliasgar.nasir at patni.com
Mon Jul 4 11:42:16 UTC 2005
Hi everyone...
I have been searching the entry point of a task in the Task Control Block of
RTEMS...
Following is the structure  Thread_Start_information which is a member of
RTEMS TCB
typedef struct {
  Thread_Entry         entry_point;      /* starting thread address
  Thread_Start_types   prototype;        /* how task is invoked
  void                *pointer_argument; /* pointer argument
  unsigned32           numeric_argument; /* numeric argument
                                         /* initial execution modes
  boolean              is_preemptible;
  Thread_CPU_budget_algorithms          budget_algorithm;
  Thread_CPU_budget_algorithm_callout   budget_callout;
  unsigned32           isr_level;
  Priority_Control     initial_priority; /* initial priority
  boolean              core_allocated_stack;
  Stack_Control        Initial_stack;    /* stack information
#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
  void                *fp_context;       /* initial FP context area address
#endif
  void                *stack;            /* initial stack area address
}   Thread_Start_information;
However on debugging my code i found that the entry point is not stored in
Thread_entry entry_point but is stored in unsigned32
numeric_argument......Can anyone tell me the reason why and also what is
meant by numeric argument...also let me know if there is any documentation
available to describe each member of the TCB.
Regards
Ali Asgar
http://www.patni.com
World-Wide Partnerships. World-Class Solutions.
_____________________________________________________________________
This e-mail message may contain proprietary, confidential or legally
privileged information for the sole use of the person or entity to
whom this message was originally addressed. Any review, e-transmission
dissemination or other use of or taking of any action in reliance upon
this information by persons or entities other than the intended
recipient is prohibited. If you have received this e-mail in error
kindly delete  this e-mail from your records. If it appears that this
mail has been forwarded to you without proper authority, please notify
us immediately at netadmin at patni.com and delete this mail.
