bdbuf: Disk I/O buffering
Eugeny S. Mints emints at ru.mvista.com
Tue Jul 5 14:57:13 UTC 2005
Joel Sherrill  wrote:
> Kirspel, Kevin {Engineering - Osmetech CCD} wrote:
>> The patch fixes the swapout() problem. As you mention earlier, I now
>> have other issues that I will have to work out.  If anything is
>> relevant, I will update this thread.
> Should this patch be considered trusted at this point and applied
> to CVS?
I believe so - it definitly fixes one bug.
	Eugeny
>> Kevin Kirspel
>> Osmetech 235 Hembree Park Drive
>> Roswell GA, 30076
>> 770-510-4444 x568
>> -----Original Message-----
>> From: Eugeny S. Mints [mailto:emints at ru.mvista.com] Sent: Monday, July
>> 04, 2005 7:38 AM
>> To: Eugeny S. Mints
>> Cc: Kirspel, Kevin {Engineering - Osmetech CCD}; rtems-users at rtems.com
>> Subject: Re: bdbuf: Disk I/O buffering
>> forgot to mention:
>> first, sorry for the patch format, second the patch is agains 4.6.0
>> and the third I've never compiled/tested it.
>>     Eugeny
>> Eugeny S. Mints wrote:
>>> Hello Kevin,
>>>> I have built an rtems 4.6.0 release and it has worked beautifully for
>> 2
>>>> years.  I added compact flash support to my build by using the IDE
>>>> interface in rtems.  Every thing works great as long as I keep the
>>>> compact flash card in the system. I wanted to add support to rtems so
>>>> that I may remove and insert the compact flash card whenever I want.
>> I
>>>> now probe() the compact flash device to make sure it is in place
>> before
>>>> I perform any ata_ioctl() commands. If the device is not in place, I
>>>> return -1 with errno = ENODEV. This causes the bdbuf_swapout_task()
>>>> function to enter an indefinite loop because it keeps on trying to
>> call
>>>> the ata_ioctl() routine with no success.
>>>> The following code is taken from the bdbuf_swapout_task() function in
>>>> bdbuf.c:
>>>> /* transfer_sema initialized when bd_buf inserted in the mod chain
>>>>   first time */
>>>> result = dd->ioctl(dd->phys_dev->dev, BLKIO_REQUEST, &req);
>>>> rtems_disk_release(dd);
>>>> if (result == -1)
>>>>  bd_buf->status = RTEMS_IO_ERROR;
>>>>  bd_buf->error = errno;
>>>>  /* Release tasks waiting on syncing this buffer */
>>>>  _CORE_mutex_Flush(&bd_buf->transfer_sema, NULL,
>>>> CORE_MUTEX_STATUS_SUCCESSFUL);
>>>> else
>>>>  if (bd_buf->in_progress)
>>>>    rtems_interrupt_disable(level);
>>>>    _CORE_mutex_Seize(&bd_buf->transfer_sema, 0, TRUE, 0, level);
>>>> I am not a disk buffering guru, but what can I do to the
>>>> bdbuf_swapout_task() ( or other functions ) to make it process the
>> error
>>>> so that at the higher levels and error code is returned.
>>> Apart from that there is a bug that you discovered, the higher levels
>>> are aware about status/error of this low level I/O via bd_buf->status
>>> and bd_buf->error fields which are filled either in "if (result ==
>> -1)"
>>> branch above (the swapout task algo is: a higher level task is
>> awaiting
>>> for a buffer blocking on transfer sema; the buffer is removed from
>>> swapout task's queue of buffers to process at Chain_Get() and at
>>> transfer sema release time higher level task gets control on a buffer
>>> back with bd_buf status and error fields set appropriately) or at
>>> bdbuf_write_transfer_done() execution time.
>>> The bug you discovered is the following:
>>> at the time ioclt returns "-1 " bd_buf->modified field is set. But a
>> bit
>>> below at
>>>        if (bd_buf->use_count == 0)
>>>            if (bd_buf->modified)
>>>                Chain_Append(&bd_ctx.mod, &bd_buf->link);
>>>                rc = rtems_semaphore_release(bd_ctx.flush_sema);
>>>            else
>>>                Chain_Append(&bd_pool->lru, &bd_buf->link);
>>>                rc = rtems_semaphore_release(bd_pool->bufget_sema);
>>> since bd_buf->modified is not re-set (at normal path this field is
>> reset
>>> at bdbuf_write_transfer_done() before this part of code execution) the
>>> rtems_semaphore_release(bd_ctx.flush_sema) leads to the infinit
>> cycling
>>> in swapout task.
>>> Please let us know whether the patch attached fixes your problem (at
>>> least inifinit cycling).
>>>> My current scenario is this:
>>>> 1. I boot the system with the compact flash card in place.
>>>> 2. After task initialization, my main task initializes the ide
>>>> partitions, mounts the drive, opens a file, writes data to the file,
>>>> closes the file, and unmounts the drive. This works great.
>>>> 3. I then remove the compact flash and repeat the process.
>>>> 4. During the mount process, the system hangs in bdbuf_swapout_task()
>> do
>>>> to the fact that the dd->ioctl() returns -1;
>>> Based on your scenario I'm concerned about whether the bug in swapout
>>> taks is the main issue.
>>> My understanding is that the scenario with removed flash shoud end up
>> in
>>> mount() call (more exaclty in
>> msdos_initialize_support()->fat_init_volume_info()->rtems_disk_lookup()
>>> (if you use fat fs ) since rtems_disk_lookup() should fail if there is
>>> no actual disk) and has not to have any deal with swapout task at all.
>>>    Eugeny
>>>> Kevin Kirspel
>>>> Roswell GA, 30076
>>>> 770-510-4444 x568
>>> --- bdbuf.old.c    2005-07-04 15:21:52.000000000 +0400
>>> +++ bdbuf.c    2005-07-04 15:23:28.000000000 +0400
>>> @@ -1545,7 +1545,7 @@
>>>          * and release semaphore */
>>> -            if (bd_buf->modified)
>>> +            if ((bd_buf->status != RTEMS_IO_ERROR) &&
>> (bd_buf->modified))
