bdbuf: Disk I/O buffering
Kirspel, Kevin {Engineering - Osmetech CCD} kevin.kirspel at osmetech.com
Tue Jul 5 18:26:23 UTC 2005
With the patch you sent, "bd_buf->in_progress" and "bd_buf->modified"
are left unchanged. This causes a problem with find_or_assign_buffer()
who looks at the "bd_buf->in_progress" to complete. Is it appropriate to
set "bd_buf->in_progress" and "bd_buf->modified" to FALSE if an error
occurs during bdbuf_swapout_task()?
Kevin Kirspel
Osmetech
235 Hembree Park Drive
Roswell GA, 30076
770-510-4444 x568
-----Original Message-----
From: Eugeny S. Mints [mailto:emints at ru.mvista.com]
Sent: Tuesday, July 05, 2005 10:55 AM
To: Kirspel, Kevin {Engineering - Osmetech CCD}
Cc: rtems-users at rtems.com; Victor Vengerov
Subject: Re: bdbuf: Disk I/O buffering
Kirspel, Kevin {Engineering - Osmetech CCD} wrote:
> Where do the "bd_buf->status" and "bd_buf->error" variables get check
in
> the higher level functions?
wow! good question:)
those have to be checked every time by any function which is going to
rely on a bd_buf data. Thus for example after each rtems_bdbuf_read()
invocation and before bd_buf data utilization. Most probably there are
potential bugs related to lack of such verification. You are welcome..:)
	Eugeny
> Kevin Kirspel
> Osmetech
> Roswell GA, 30076
> 770-510-4444 x568
> From: Kirspel, Kevin {Engineering - Osmetech CCD}
> [mailto:kevin.kirspel at osmetech.com]
> Sent: Tuesday, July 05, 2005 9:27 AM
> To: Eugeny S. Mints
> Subject: RE: bdbuf: Disk I/O buffering
> The patch fixes the swapout() problem. As you mention earlier, I now
> have other issues that I will have to work out.  If anything is
> relevant, I will update this thread.
> Kevin Kirspel
> Osmetech
> Roswell GA, 30076
> 770-510-4444 x568
> Sent: Monday, July 04, 2005 7:38 AM
> To: Eugeny S. Mints
> Cc: Kirspel, Kevin {Engineering - Osmetech CCD}; rtems-users at rtems.com
> forgot to mention:
> first, sorry for the patch format, second the patch is agains 4.6.0
and
> the third I've never compiled/tested it.
> 	Eugeny
> Eugeny S. Mints wrote:
>>Hello Kevin,
>>>I have built an rtems 4.6.0 release and it has worked beautifully for
> 2
>>>years.  I added compact flash support to my build by using the IDE
>>>interface in rtems.  Every thing works great as long as I keep the
>>>compact flash card in the system. I wanted to add support to rtems so
>>>that I may remove and insert the compact flash card whenever I want.
> I
>>>now probe() the compact flash device to make sure it is in place
> before
>>>I perform any ata_ioctl() commands. If the device is not in place, I
>>>return -1 with errno = ENODEV. This causes the bdbuf_swapout_task()
>>>function to enter an indefinite loop because it keeps on trying to
> call
>>>the ata_ioctl() routine with no success.
>>>The following code is taken from the bdbuf_swapout_task() function in
>>>bdbuf.c:
>>>/* transfer_sema initialized when bd_buf inserted in the mod chain
>>>   first time */
>>>result = dd->ioctl(dd->phys_dev->dev, BLKIO_REQUEST, &req);
>>>rtems_disk_release(dd);
>>>if (result == -1)
>>>  bd_buf->status = RTEMS_IO_ERROR;
>>>  bd_buf->error = errno;
>>>  /* Release tasks waiting on syncing this buffer */
>>>  _CORE_mutex_Flush(&bd_buf->transfer_sema, NULL,
>>>CORE_MUTEX_STATUS_SUCCESSFUL);
>>>else
>>>  if (bd_buf->in_progress)
>>>    rtems_interrupt_disable(level);
>>>    _CORE_mutex_Seize(&bd_buf->transfer_sema, 0, TRUE, 0, level);
>>>I am not a disk buffering guru, but what can I do to the
>>>bdbuf_swapout_task() ( or other functions ) to make it process the
> error
>>>so that at the higher levels and error code is returned.
>>Apart from that there is a bug that you discovered, the higher levels
>>are aware about status/error of this low level I/O via bd_buf->status
>>and bd_buf->error fields which are filled either in "if (result ==
> -1)"
>>branch above (the swapout task algo is: a higher level task is
> awaiting
>>for a buffer blocking on transfer sema; the buffer is removed from
>>swapout task's queue of buffers to process at Chain_Get() and at
>>transfer sema release time higher level task gets control on a buffer
>>back with bd_buf status and error fields set appropriately) or at
>>bdbuf_write_transfer_done() execution time.
>>The bug you discovered is the following:
>>at the time ioclt returns "-1 " bd_buf->modified field is set. But a
> bit
>>below at
>>        if (bd_buf->use_count == 0)
>>            if (bd_buf->modified)
>>                Chain_Append(&bd_ctx.mod, &bd_buf->link);
>>                rc = rtems_semaphore_release(bd_ctx.flush_sema);
>>            else
>>                Chain_Append(&bd_pool->lru, &bd_buf->link);
>>                rc = rtems_semaphore_release(bd_pool->bufget_sema);
>>since bd_buf->modified is not re-set (at normal path this field is
> reset
>>at bdbuf_write_transfer_done() before this part of code execution) the
>>rtems_semaphore_release(bd_ctx.flush_sema) leads to the infinit
> cycling
>>in swapout task.
>>Please let us know whether the patch attached fixes your problem (at
>>least inifinit cycling).
>>>My current scenario is this:
>>>1. I boot the system with the compact flash card in place.
>>>2. After task initialization, my main task initializes the ide
>>>partitions, mounts the drive, opens a file, writes data to the file,
>>>closes the file, and unmounts the drive. This works great.
>>>3. I then remove the compact flash and repeat the process.
>>>4. During the mount process, the system hangs in bdbuf_swapout_task()
> do
>>>to the fact that the dd->ioctl() returns -1;
>>Based on your scenario I'm concerned about whether the bug in swapout
>>taks is the main issue.
>>My understanding is that the scenario with removed flash shoud end up
> in
>>mount() call (more exaclty in
msdos_initialize_support()->fat_init_volume_info()->rtems_disk_lookup()
>>(if you use fat fs ) since rtems_disk_lookup() should fail if there is
>>no actual disk) and has not to have any deal with swapout task at all.
>>    Eugeny
>>>Kevin Kirspel
>>>Osmetech 235 Hembree Park Drive
>>>Roswell GA, 30076
>>>770-510-4444 x568
>>--- bdbuf.old.c	2005-07-04 15:21:52.000000000 +0400
>>+++ bdbuf.c	2005-07-04 15:23:28.000000000 +0400
>>@@ -1545,7 +1545,7 @@
>>          * and release semaphore */
>>-            if (bd_buf->modified)
>>+            if ((bd_buf->status != RTEMS_IO_ERROR) &&
> (bd_buf->modified))
