current cvs on powerpc
Jennifer Averett jennifer.averett at oarcorp.com
Mon Jul 11 13:06:06 UTC 2005
Ed,
Looking at the Changelog the ss555 already supported the new exception
model when I made the modifications.
It looks like the gen405 is one that I missed converting.  If you look in
the "make/custom/gen405.cfg" file, CPU_FLAGS has D_OLD_EXCEPTIONS added to
it.  However, there are changes to the bsp code which are necessary prior
to supporting new exceptions so just changing this option alone will not
make the bsp work with new exceptions.
Jennifer
>> In RTEMS-CVS/4.7, adding -D_OLD_EXCEPTIONS_PROCESSING to your CFLAGS
>> should do, ... if your BSP is ready to support both kind of exceptions.
> Sorry if I'm just making this confusing, but the gen405 bsp builds that
> way by default.  I didn't touch anything to cause it to build with the
> old-exception-processing model.  Is it possible that the gen405 bsp was
> not updated to use the new-exception-processing model?
> Ed
