Re: current cvs on powerpc
emu at ecubics.com emu at ecubics.com
Mon Jul 11 13:36:21 UTC 2005
Ralf Corsepius wrote:
> On Fri, 2005-07-08 at 16:13 -0600, emanuel stiebler wrote:
>>Hi all,
>>still trying to compile RTEMS for PowerPC, getting further, but:
>>------------------------ cut -----------------------------------
>>powerpc-rtems-gcc --pipe -B../../../../.././lib/
>>-B../../../../.././ss555/lib/ -
>>gmake[1]: Leaving directory `/SHARED1/RTEMS/build-rtems-cvs/powerpc-rtems/c'
>>make: *** [all-recursive] Error 1
> You seem to be using vanilla automake, you must use the patched automake
> from the RTEMS site to build RTEMS CVS.
Hello Ralf,
you are right. I thought I was using the new RTEMS versions of automake and autoconf, but my $PATH was wrong :(
Thanks
