examples not working with CVS head (todays sources) on pc386 BSP.
Karel Gardas kgardas at objectsecurity.com
Thu Jul 14 10:31:12 UTC 2005
Hello,
short followup, the same happen for powerpc-rtems/psim platform/bsp too.
I've downloaded those examples from 4.6.2 release:
ftp://rtems.com:/pub/rtems/4.6.2
Thanks,
Karel
On Thu, 14 Jul 2005, Karel Gardas wrote:
> Hello,
> I try to compile hello_world_c application as described on:
> http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.6.2/share/rtems/html/started/started00064.html
> I've followed the doc and succesfully compiled i386-rtems toolchain and also
> pc386 rtems BSP of todays' CVS head source tree (RTEMS 4.7). I've set
> appropriate env. var:
> silence:/tmp/rtems/examples-4.6.2/hello_world_c$ echo $RTEMS_MAKEFILE_PATH
> /home/karel/usr/local/pc386-i386-rtems-bsp/i386-rtems/pc386/
> but unfortunately simple `make' as describe in doc above does not work:
> silence:/tmp/rtems/examples-4.6.2/hello_world_c$ make
> i386-rtems-gcc --pipe
> -B/home/karel/usr/local/pc386-i386-rtems-bsp/i386-rtems/pc386/lib/ -specs
> bsp_specs -qrtems   -g -Wall  -O4 -g         -c   -o o-optimize/test.o test.c
> test.c:31:22: error: confdefs.h: No such file or directory
> make: *** [o-optimize/test.o] Error 1
> The toolchain is new gcc4.0.0/binutils2.16.1/newlib1.13 and all required
> rtems patches applied.
> Are there any new instruction needed for examples to be built with RTEMS 4.7?
> Thanks,
> Karel
> ObjectSecurity Ltd.           http://www.objectsecurity.com
