To much memory allocated in _Objects_Extend_information()?
John Alexandersson john.alexandersson at space.se
Fri Jul 15 11:27:41 UTC 2005
Hi all,
I'm sitting here looking at the code in
score/src/objectextendinformation.c and I don't quite understand how
the size of the memory to allocate is calculated.
(RTEMS v4.6.2; objectextendinformation.c,v 1.4.2.1 2003/09/04 18:52:47)
Here is an extract of the code which puzzles me:
---8<------------------------------------------------
     *  Allocate the tables and break it up.
    if ( information->auto_extend ) {
      object_blocks = (void**)
        _Workspace_Allocate(
          block_count *
             (sizeof(void *) + sizeof(unsigned32) + sizeof(Objects_Name *)) +
          ((maximum + minimum_index) * sizeof(Objects_Control *))
      if ( !object_blocks )
        return;
    else {
        _Workspace_Allocate_or_fatal_error(
          block_count *
More precise, it is the last part that I find strange:
Is it correct behaviour to _add_ minimum_index? Shouldn't it be
subtracted instead? (maximum - minimum_index)?
If it, in fact, is the correct behaviour, could some one please
explain why?
To me it looks like too much memory is allocated here, but since I
haven't quite got a grip of the overall handling of Objects yet, I
might very well be wrong.
Thanks for enlighten me,
/John Alexandersson - Saab Ericsson Space AB
\ /    ASCII Ribbon Campaign
 X   against HTML email & vCards
/ \    Keep Email as ASCII
